[info] 134 pin breakout 967288
BMW likes this 134 pin header 967288 https://www.te.com/usa-en/product-7-967288-1.html - seems to be used all the way from 3 series e46 to v12 e65/e66
Also known as 965497-1
Seems to be same outer shape as 121 pin
https://www.ebay.com/itm/333534819202
Re: 134 pin breakout 967288
Some documentation refers to this as Standard Shell Construction connector.
And my v12 seems to be using it.
https://github.com/rusefi/rusefi/tree/master/hardware/Breakout_134pin_7-967288-1-Connector paper test is a success!
I have a couple of new connectors arriving in a few days.
Progress
Is that a miracle? It has simply snapped in as expected. Rev 0.1 seems to be a complete and utter success.
Sweet and don't jinks it. I kind of wanted fatter traces, or at least a cup holder :)
1)                  left and right side x9 pin section need much wider traces at least where possible - some of those are used for not smart coils thus higher current.
is it even possible to make single 1oz traces work with not smart coil current?
Sat May 30, 2020 12:31 am
of course - plenty of OEM ECUs do it. You just have to use a trace wider than 10-12 thou or whatever it is on this board.
We have more copper in version 0.2
We also have some gerber diff magic which I am not yet sure how to read at https://rusefi.com/docs/diffs/plots_134pin_7-967288-1/web/
Diff is cool.
