My own brain board
Ahmad
My own brain board
Post by Ahmad »
After 5 days, my brain board pcb is finished :?
I want to use screw-less connector(MX250B-3.5) for mother board, because the test engine is a stationary generator.
Any comment?
Re: My own brain board
I would recommend having 4 status LEDs for firmware diagnostics, see https://rusefi.com/forum/viewtopic.php?f=4&t=381
Without schematics with just a picture there is too little information.
Why do you believe that a new brain board is necessary? Looks like there are SO many boards :)
Post by Abricos »
LED ?
Ahmad
Post by Ahmad »
Thanks for new topic.
LEDs can be placed on mother board instead of brain board. The brain board may be used for other projects.
I use Altium and our local PCB makers have some limits on manufacturing (clearance, pad/via size, ...).
The price and size of an STM32F4Discovery and its extra components lead me to make my own brain board.
I want to test RusEfi code for testing and learning, because my experiences is low level programming and RusEfi code is high level.
Now my doubt is connector selection for mother board. I want to have some flexibility on wiring.
Ahmad
Post by Ahmad »
Abricos wrote:
Wed Sep 11, 2019 1:32 pm
LED ?
4 LEDs are for 3.3V, USB5V, SDcard and Debug.
Schematic:
Brain_Board_Sch_Ahmad_V1.pdf
(810.73 KiB) Downloaded 66 times
Ahmad
Post by Ahmad »
I have another question.
Is the free Tuner Studio best choice for monitoring/tuning?
May last project was a generator controller/monitoring and I wrote my own software.
Best choice is a vague term. It's free, and it works. For many that makes it the best. However best is in the eyes of the beholder. The console also several features which are not options in TS.
Ahmad wrote:
Wed Sep 11, 2019 1:47 pm
LED Debug.
So you have one debug LED that's something! I would recommend at least two debug LEDs. Please be aware that you would need to compile your own firmware if you want your FATAL ERROR debug LED to be on a custom pid, FATAL ERROR could not be adjusted via configuration by design.
rusEfi stm32f407 default firmware uses
#define LED_ERROR_BRAIN_PIN GPIOD_14
Ahmad
Post by Ahmad »
russian wrote:
Wed Sep 11, 2019 10:05 pm
So you have one debug LED that's something! I would recommend at least two debug LEDs. Please be aware that you would need to compile your own firmware if you want your FATAL ERROR debug LED to be on a custom pin, FATAL ERROR could not be adjusted via configuration by design.
Thanks to notification Andrey
I'm drawing mother board and will connect any unused pin to a LED :)
but I don't understand "FATAL ERROR could not be adjusted via configuration by design".
you means, I can't change pin definitions in your source code and then compile?
no, i only mean it could not be adjusted after compiling. everyghing else could be sdjusted via tunerstudio but not that.
if you can recompile you are good. it would be easier to use standard official binaries
Ahmad
Post by Ahmad »
My experimental ECU board is complete and now i want to edit firmware to match it.
the board consist of:
- STM32F407V module
- L9779 module for Digital I/O, Stepper motor Driver(we have gas mixer instead of injectors), ...
- CJ125(TQFP) module for Lambda
- IGBT module with current sense for ignition
- LAN (w5500) module
- RS485 (ADM2587E) module
- WiFi(ESP8266) module with current softener supply
- TLE9201SG for ETB
