Page 11 of 12
Posted: Mon Jan 17, 2022 11:32 am
by Abricos
I have EGT ...
I use EGT ...
Posted: Mon Jan 17, 2022 5:15 pm
by Lambo97
Interesting, Soon we will be able to run Pulsejet or Turbine with Rus EFI!
Posted: Mon Jan 17, 2022 8:13 pm
by JRD McLAREN
Lambo97 wrote: ↑Mon Jan 17, 2022 5:15 pm
Contact Colin Furze ...
Posted: Fri Feb 04, 2022 3:35 pm
Available at
https://www.shop.rusefi.com/
No longer available on eBay
Posted: Fri Feb 04, 2022 6:18 pm
by puff
wtf?? is there any rationale behind that decision by eBay?
Posted: Wed Feb 09, 2022 5:26 pm
by Simon@FutureProof
Banning all "emissions defeat devices" basically.
Seems to be ebay.com only
Posted: Thu Feb 10, 2022 12:54 pm
by Abricos
OrchardPerformance wrote: ↑Wed Feb 09, 2022 5:26 pm
But VAG TDI ECU still for sale on ebay ...))))
Posted: Tue Feb 15, 2022 10:05 pm
Posted: Fri Mar 11, 2022 12:50 pm
by subzero
can i use stm32f407zgt6 or i need stm32f429?
Posted: Fri Mar 11, 2022 4:38 pm
subzero wrote: ↑Fri Mar 11, 2022 12:50 pm
no stm32f407zgt6
https://github.com/rusefi/rusefi/wiki/Chip-Shortage-Parts-Interchange says "256KB RAM required" which stm32f407zgt6 is not
Posted: Sun Apr 10, 2022 11:19 pm
by kneelo
Finally installed my v0.3 in my latest track car (Holden VE commodore with the LEO Alloytec HFV6). Car starts and runs... yay!
There are a few errors on the online pinout diagram for the 23pin connector I found in the process of getting it working. The main one is that pin 14 is listed as a gnd but is actually one of the usb comms lines. I was losing Usb whenever this plug was connected until I checked the schematic.
There was a couple of other pins that were also wrong related to usb signals on this connector, I think maybe these were marked as the canbus lines on the pinout from memory. I assume there has been a hardware change at some point between versions.
Also is there a summary anywhere of the hardware mods required to get the knock sensing working? If chip availability wasnt an issue I would probably just go with a new board. As it is Im thinking I might try and kludge this board.
Posted: Sun Apr 10, 2022 11:27 pm
kneelo wrote: ↑Sun Apr 10, 2022 11:19 pm
You would not believe it -
https://github.com/mck1117/proteus/blob/master/changelog.md was created about a week ago
I've just mentioned USB removal on the changelog.
Posted: Sat Apr 30, 2022 11:22 am
by subzero
Just a question bought for my w201 2.3 8v denso honda hall sensor that needs 12 volt and outpouts 12 volt square signal
Proteus can accept 12 volt digital input for rpm signal?
Posted: Sat Apr 30, 2022 3:33 pm
Yes digital inputs are 12v tolerant when official parts were soldered.
Posted: Sat Oct 08, 2022 4:45 pm
by tmbryhn
Is the LPS22HHTR sensor compatible with Proteus firmware?
According to datasheet, it should have the exact same footprint and pinout as the current LPS25HB, and also the same pressure range.
LPS25HB:
https://no.mouser.com/ProductDetail/511-LPS22HHTR
LPS22HHTR:
If not compatible; would it be an option to tweak the firmware to allow for use of multiple alternatives during these times of supply chain issues?
Posted: Sat Oct 08, 2022 4:54 pm
by mck1117
Yes, the firmware supports both
Posted: Sat Oct 08, 2022 5:46 pm
digikey just randomly had x86 of VNLD5090 in stock a week ago and those were in fact delivered today!
Mouser was promising VNLD5300 with 11/2022 delivery, three days after order it's 03/2023 delivery
Posted: Wed Feb 01, 2023 5:09 pm
mck1117 wrote: ↑Fri Oct 15, 2021 6:22 pm
The cap I have is CAP-WADMLPC2.
UB-20AFMM-LL7A01 is matching USB cable.
Posted: Sat Apr 29, 2023 1:57 pm
Note to self: serial still works
RX pin is green on my blue uart device but that's totally not standardized
- image.png (200.7 KiB) Viewed 57821 times
Posted: Thu Jun 29, 2023 5:49 am
Low side 13 output has a flyback diode, is that output good to control relays at all? At the moment
https://rusefi.com/docs/pinouts/proteus/ list LS13 as suggested main relay control pin.
More info on my issue at
https://rusefi.com/forum/viewtopic.php?p=47930#p47930
Posted: Tue Jul 25, 2023 9:15 pm
I have a bunch of damaged proteus returns - those units are both blue (not JLC) and black (JLC)
Most obvious test which fails - units do not stay in DFU mode if powered by UBS. Reference red good unit stays in DFU mode a while while damaged units just reset out of DFU mode, then start running main firmware, then again reboot or hand while in main firmware.
https://github.com/rusefi/proteus/issues/2
Posted: Thu Aug 31, 2023 5:35 pm
by mtmotorsport
Are the injector drivers on Proteus capable of handing 8.5ohm injectors? Specifically Bosch 0 280 158 333 injectors.
The datasheet for VNLD5160 doesn't specify if the 3.5amp drain current is per channel or total. If per channel that would be fine, if total it might run into some thermal issues?
I've searched and can't find an answer.
Posted: Thu Aug 31, 2023 10:20 pm
by JRD McLAREN
It is per channel ...
and it has overvoltage and overcurrent protection ..
...thermal also ...
..when you are not sure, change it to VNLD5090
https://www.mouser.sk/datasheet/2/389/vnld5090_e-1852805.pdf
Posted: Fri Sep 01, 2023 3:22 am
Yes VNLD5090 are in stock but at some point it becomes a heat dissipation question, I am not qualified to run the actual math.
Posted: Thu Sep 21, 2023 9:16 pm
by atntpt
I have an ancient version of proteus lying around that I never used because knock was broken, v0. 3! There is any hardware mod I can make to have it working? I don't need nothing fancy, it's not a race car, but its supercharged and I would like to have some safety in case something fails.
Posted: Tue Nov 21, 2023 4:22 am
JRD McLAREN wrote: ↑Thu Aug 31, 2023 10:20 pm
I am having issues using VNLD5090 with higher current. Working on a vehicle with direct fuel pump control without a relay: one vehicle / one Proteus fuel pump was operating great I did not even have to look at the numbers. Another same vehicle / a few different Proteus units I have locally are failing to drive 4A.
Vladimir says VNLD5090 is not guaranteed to drive 4A if we control it with just 3V? I've jumped 5v from IGN6 to drive a VNLD5090 and got short-term 4A fuel pump control only to see VNLD5090 get hot and current drops to 2A pump stops pumping
- WhatsApp Image 2023-11-20 at 23.15.21_dcb4954e.jpg (313.63 KiB) Viewed 51537 times
Posted: Tue Nov 21, 2023 4:57 am
by mck1117
AndreyB wrote: ↑Tue Nov 21, 2023 4:22 am
Does that channel have a diode fitted?
Posted: Tue Nov 21, 2023 12:07 pm
mck1117 wrote: ↑Tue Nov 21, 2023 4:57 am
I've tried this both with and without. Red board with 5v control jumper wire has diode while say white board without the control wire mod does not have the diode.
Posted: Tue Nov 21, 2023 2:18 pm
by JRD McLAREN
Fuel Pump is DC Motor with brushes...
Posted: Tue Nov 21, 2023 2:20 pm
JRD McLAREN wrote: ↑Tue Nov 21, 2023 2:18 pm
OK?
The snow is usually white.
