Page 12 of 12
Posted: Tue Nov 21, 2023 2:29 pm
by JRD McLAREN
as you say .. You have two identical setups ...
but two different fuel pumps ...
one is wrong, maybe ...
poor condition, different type of DC motor ...
(no caps and/or inductor inside, etc)
..and VNLD5090 can't handle this situation ...
try to use different type of load (bulb .?? ) on this output ..
Posted: Fri Dec 01, 2023 3:00 pm
by Atlantis2013
Hi everyone
BTS4175SGA isn't available .
Can use BSP762TXUMA1 for remplacement ?
Thx
Posted: Fri Dec 01, 2023 4:39 pm
Atlantis2013 wrote: ↑Fri Dec 01, 2023 3:00 pm
https://rusefi.com/forum/search.php?keywords=BSP762
Posted: Mon Jan 29, 2024 8:29 pm
by Bruno Ferreira
The Proteus v0.7
See pic1,pic2,pic3 and pic4,there are thin traces like pointed on the every copper layer and they do not connect the pads around them,so the thin trace will be cut after production.
And the width of them are less than 0.15mm,which are too small to make.
If this is correct, I suggest updating these points.
Posted: Mon Jan 29, 2024 9:47 pm
by mck1117
I don't see this issue either in KiCad or in the official gerber output files.
![image.png](./download/file.php?id=11164)
- image.png (125.53 KiB) Viewed 15041 times
Posted: Tue Jan 30, 2024 12:24 pm
by Bruno Ferreira
It's just a production defect. When printing layers, the machine only prints with quality from 0.15
I changed them all to 0.5588
Perfect Gnd contact and no hot spots
Posted: Mon Feb 26, 2024 5:21 pm
by pc1010
Hi!
Did anyone manage to make EGT work on Proteus board using the AUX SPI connector?
It looks to be laid out on SPI5 port
![Zrzut ekranu 2024-02-26 163441.png](./download/file.php?id=11306)
- Zrzut ekranu 2024-02-26 163441.png (20.3 KiB) Viewed 11566 times
![Zrzut ekranu 2024-02-26 181724.png](./download/file.php?id=11307)
- Zrzut ekranu 2024-02-26 181724.png (64.27 KiB) Viewed 11566 times
Posted: Mon Feb 26, 2024 5:27 pm
At the moment rusEFI focuses on spi1 to 3 with one random spot mentioning spi4. Do not see any spi5 code anywhere.
custom spi_device_e 1 bits, U08, @OFFSET@, [0:2], "Off", "SPI1", "SPI2", "SPI3", "SPI4"
Posted: Mon Feb 26, 2024 5:28 pm
