Unable to do MicroRusEFI first flash on new pre-assembled board [update: microUSB connector failure]
Posted: Sat May 09, 2020 2:41 am
Hello all,
My Miata engine exploded the other week so I bought a MicroRusEFI for a different project.
I received a preassembled Microrusefi the other day and I attempted to flash the firmware on my Linux desktop, but it looks like this board doesn't work.
I plugged it in to my computer holding PROGRAM to boot into DFU. Upon connecting, lsusb does not show microrusefi.
So I thought this may be a driver issue. In order to investigate further, I reconnected it to my computer and ran dmesg. Dmesg shows NO evidence my computer had a USB device plugged into it. I tried 3 different USB cables with no results. I retried without booting into DFU, and I get the same result. I also tried 2 different Windows computers and I can't get the device to show up on any of them.
All LEDs on the board are blinking as intended. Attached is the output of dmesg, and the board in DFU as well as regular mode. I've not modified the board in any way or even plugged in my connector.
Upon request, I also made an attempt to communicate with the board in non-DFU mode. So I plugged in the board into my PC NOT holding program as normal and did dmesg. This time it looks like Linux attempted to communicate with the board but failed. lsusb shows nothing. I also tried this with several different USB cables, still no change.
This was the output:
I'm fairly convinced that I received a faulty board, but I may be doing something wrong.
Thank you!
[ 2470.465898] usb 1-10: Device not responding to setup address.
[ 2470.672219] usb 1-10: device not accepting address 14, error -71
[ 2470.795554] usb 1-10: new low-speed USB device number 15 using xhci_hcd
[ 2470.795991] usb 1-10: Device not responding to setup address.
[ 2471.002729] usb 1-10: Device not responding to setup address.
[ 2471.208884] usb 1-10: device not accepting address 15, error -71
[ 2471.208986] usb usb1-port10: unable to enumerate USB device
[ 2510.352432] usb 1-10: new low-speed USB device number 16 using xhci_hcd
[ 2510.475782] usb 1-10: device descriptor read/64, error -71
[ 2510.705794] usb 1-10: device descriptor read/64, error -71
[ 2510.935769] usb 1-10: new low-speed USB device number 17 using xhci_hcd
[ 2511.059125] usb 1-10: device descriptor read/64, error -71
[ 2511.289142] usb 1-10: device descriptor read/64, error -71
[ 2511.399081] usb usb1-port10: attempt power cycle
[ 2512.042457] usb 1-10: new low-speed USB device number 18 using xhci_hcd
[ 2512.043372] usb 1-10: Device not responding to setup address.
[ 2512.250372] usb 1-10: Device not responding to setup address.
[ 2512.455777] usb 1-10: device not accepting address 18, error -71
[ 2512.579125] usb 1-10: new low-speed USB device number 19 using xhci_hcd
[ 2512.579618] usb 1-10: Device not responding to setup address.
[ 2512.786212] usb 1-10: Device not responding to setup address.
[ 2512.992458] usb 1-10: device not accepting address 19, error -71
[ 2512.992551] usb usb1-port10: unable to enumerate USB device
[ 2540.462647] usb usb1-port10: Cannot enable. Maybe the USB cable is bad?
[ 2540.585943] usb 1-10: new low-speed USB device number 21 using xhci_hcd
[ 2541.535962] usb 1-10: device descriptor read/64, error -71
[ 2541.972636] usb 1-10: device descriptor read/64, error -71
[ 2542.079354] usb usb1-port10: attempt power cycle
[ 2542.929283] usb 1-10: new low-speed USB device number 22 using xhci_hcd
[ 2542.929764] usb 1-10: Device not responding to setup address.
[ 2543.136387] usb 1-10: Device not responding to setup address.
[ 2543.342614] usb 1-10: device not accepting address 22, error -71
[ 2544.715992] usb usb1-port10: Cannot enable. Maybe the USB cable is bad?
[ 2544.716079] usb usb1-port10: unable to enumerate USB device
[ 2545.559298] usb 1-10: new low-speed USB device number 24 using xhci_hcd
[ 2545.682654] usb 1-10: device descriptor read/64, error -71
[ 2545.912656] usb 1-10: device descriptor read/64, error -71
[ 2546.142634] usb 1-10: new low-speed USB device number 25 using xhci_hcd
[ 2546.269325] usb 1-10: device descriptor read/64, error -71
[ 2546.499315] usb 1-10: device descriptor read/64, error -71
[ 2546.606044] usb usb1-port10: attempt power cycle
[ 2547.249317] usb 1-10: new low-speed USB device number 26 using xhci_hcd
[ 2547.250632] usb 1-10: Device not responding to setup address.
[ 2547.455996] usb 1-10: Device not responding to setup address.
[ 2547.662646] usb 1-10: device not accepting address 26, error -71
[ 2547.785983] usb 1-10: new low-speed USB device number 27 using xhci_hcd
[ 2547.787382] usb 1-10: Device not responding to setup address.
[ 2547.994012] usb 1-10: Device not responding to setup address.
[ 2548.199311] usb 1-10: device not accepting address 27, error -71
[ 2548.199413] usb usb1-port10: unable to enumerate USB device
Thank you!
