[info] 121 pin connector 368255-2 (same as 1241434-1)
Re: 121 pin connector
kb1gtt wrote:
Sun Dec 16, 2018 4:35 am
I don't think thickness matters that much. The connectors are reasonably strong with any PCB installed.
I will order 0.8mm just to save the planet, also 1.6mm looks so last century.
Just a random fact: Audi is placing ECUs inside a cage so that you cannot just unplug a connector. Same break away bolts like they use on steering column locks.
1)                         center hole for plastic latch is too small
side latches are fine
New connector is available at rusEfi store - https://www.tindie.com/products/russian/121-pin-ecu-connector/
Re: 121 pin connector 368255-2 (same as 1241434-1)
Working with the harness side of the connector
dvjcodec
Post by dvjcodec »
I did similar to my projects. EDC 15+ ECU is very cheap in my country. Is possible to share 3D model of connector for PCB renderings?
My hobby, my job --> Seaside Customs Garage
https://www.facebook.com/garage.seasidecustoms
My Github --> https://github.com/dvjcodec
dvjcodec wrote:
Sun Jul 07, 2019 9:04 pm
First post in this thread has links to TE site - TE site has 3D PDF and other 3D files, we used those.
dvjcodec
Post by dvjcodec »
Thank you.
I didn't know about Eagle's library for this connector and everything measured and draw footprint myself :x :x :x :x :x
dvjcodec wrote:
Sun Jul 07, 2019 10:16 pm
Thank you.
TE has lots of info, we have lots of info at https://rusefi.com/wiki/index.php?title=Hardware:OEM_connectors
We use KICAD and do not use Eagle.
dvjcodec
Post by dvjcodec »
russian wrote:
Sun Jul 07, 2019 10:17 pm
Thank you.
Nice collection.
kb1gtt wrote:
Mon Jul 08, 2019 12:39 am
I know, but when learn Eagle few years ago is hard to switch my brain to KiKad. KiKAD is a very good, and free for charge stuff.
MarenB
Post by MarenB »
Hello from Germany,
I am new to this forum and currently not running a rusefi. However, I am about to fit a megasquirt I had lying around into a road-legal offroad buggy. The vehicle's genuine ECU is a Chinese Bosch ME7.5.7 with this 121-pin connector, here named as "Korean style" version. Well, actually that ECU only uses the larger 81-pin connector, the 40-pin side is blank. My plan is to use the full size connector in a housing of a donor ECU just used to patch wires from one side to the other. This way I can hide my megasquirt somewhere else :)
Before I order the PCB at SEEED, is there anyone in Europe who already produced a batch of the pcb (and would sell one piece to me) or is anyone else interested?
Cheers,
Maren
andreika
Post by andreika »
The third option for 81-pin female connector is TE 1473244-1:
AKA "Komatsu PC200-8", "60D98D", "60D/98D", "3601115-98D-60D". It's more like "german" type (368376-1) and doesn't fit the "asian" male pcb connector (without modification). Has a "rocking lever" on the top for locking mechanism.
The corresponding male connector is TE 1746979-1:
..Which is visually undistinguishable from the "german" type 1241434-1. Still more tests needed to verify the compatibility.
andreika
Post by andreika »
Here's the drawing for the 3rd connector type (1473244-1 + 1746979-1):
