Proteus 76 pin Mitsubishi adapter
Norman has Mitsubishi GTO which in US would be Mitsubishi 3000GT. That v6 engine shares ECU with 2nd generation Eclipse and many many Lancers! Sounds like we are making an adapter and maybe a Hellen if this takes off
https://github.com/rusefi/proteus-mitsubishi76-adapter/
Proteus adapters thread
Re: Proteus adapters thread
https://github.com/rusefi/proteus-M54-adapter is an adapter for the simpler e46 models the one with older M52 style COPs
Abovementioned M54
- image (2).png (1.45 MiB) Viewed 7612 times
Arrived
Full list of https://github.com/rusefi/rusefi/wiki/Proteus#adapters-done
A starter pack to figure one of these out would be Proteus pinout and schematics of your specific adapter, and then you configure pins in TS accordingly.
https://rusefi.com/docs/pinouts/proteus/
OBD2A schematics https://github.com/rusefi/proteus-Honda-OBD2A-adapter/blob/main/proteusOBD2Ahonda/boards/proteusOBD2Ahonda-a/board/proteusOBD2Ahonda-a-schematic.pdf
Honda K schematics https://github.com/rusefi/proteus-Honda-K-125-adapter/blob/main/proteus125honda/boards/proteus125honda-a/board/proteus125honda-a-schematic.pdf
I take aliexpress pigtails, de-pin half of them to flip pin order on the other side of 23 pin (pin 1 wires to pin 8, everything else mirrored same way)
for 35 pin I use while on one end, same mirroring pin 1 becomes pin 12.
- Slack Image (2022-02-22_19-27-23-790).jpg (157.4 KiB) Viewed 6771 times
Mark should have two adapters delivered to him next week - GM E67 and dual-pinout Harley. If things go well we might Hellen both GM and Harley in the next few weeks.
First adapter for two different generations of same vehicle! This one is Harley
- WhatsApp Image 2022-03-01 at 2.13.09 PM.jpeg (1.02 MiB) Viewed 6599 times
Well, rev A was a total failure. rev B is a total success
https://rusefi.com/online/view.php?log=710
Mark will FB either this or better one soon, for now let me post this here
Wish us luck
- e38.jpeg (207.76 KiB) Viewed 2948 times
