Alternative To BMW DI module, Duramax FICM
nmstec
Post by nmstec »
It appears as though 2001-2004 6.6 LB7 Duramax used in silverados 2500HD & more, is basically the same, however with the addition of having 8 Cylinder control.
GM Part # 97720663
Bosch Part # 0281010014
Online they are ridiculous, but at my local junkyard im quoted $60 CAD. This may be a better option for me when working on DI stuff.
Who knows if this diesel FICM would still operate well enough with petrol DI?
"Dave B. 5:03 PM
Re: Alternative To BMW DI module, Duramax FICM
90,91 can bus
So you need car to sniff can-bus to start injector driver ...
nmstec wrote:
Mon Jan 17, 2022 5:34 pm
Diesel DI is usually higher voltage right? I would be concerned that diesel injector peak/hold currents could be further away than BMW GDI settings.
Mon Jan 17, 2022 6:43 pm
Good chance this is the case - these may very possibly vaporize a GDI injector.
nmstec
Post by nmstec »
Abricos wrote:
Mon Jan 17, 2022 6:32 pm
90,91 can bus
No CanBus needed for this. But also easy, CANbus is my thing. CAN is only used for diagnostics as far as I recall, and itself takes no data in.
This I am concerned about yes.
EDIT: Andrey dont kill me, I'll upload better schematics with proper names in a bit.
FICM 1.pdf
(754.94 KiB) Downloaded 167 times
FICM 2.pdf
(531.43 KiB) Downloaded 166 times
"Dave B. 5:03 PM
