Everyone loves a good distraction right?
Radlok RL00571-25 https://www.amphenol-industrial.de/en/RL00571-25/5-7mm-Radlok-plug-25mm-orange/p10796 is an alternative to good old 6mm stud
VN7003ALH sounds cool fun fact: today dev board costs $4 while single chip costs $5. A modern replacement for legacy AUIR3313S?
https://digitalcommons.calpoly.edu/eesp/387/ would be a source of inspiration
PDM info dump
PDM info dump
- Formula SAE Power Distribution Controller.pdf
- (2.71 MiB) Downloaded 145 times
- IMG_20220512_110419.jpg (336.38 KiB) Viewed 6657 times
- IMG_20220512_110450.jpg (132.38 KiB) Viewed 6657 times
Re: PDM info dump
Need help: looking for off-the-shelf hardware for positive terminal. We want a flange touching PCB and we want an eyelet outside of the case.
TDG went with everything custom including 11 head m6 internal low profile nut I would prefer to go with simpler stuff.
Let's start with M6 options?
Maybe wurth 7461098
Maybe wurth 7461084
random cool not M6 stuff
RL9057-203-F1
SLPIRBTPSR3
Maybe wurth 7461098
Maybe wurth 7461084
RL9057-203-F1
SLPIRBTPSR3
Re: PDM info dump
Let's KISS and prototype with a brass bolt https://accu-components.com/us/12-pan-head-screws?Material=Brass&Thread+Size+%28T%29=M6+%286mm%29&page=1
- Github Username: blundar
- Slack: Dave B.
- Contact:
Re: PDM info dump
The VN700x are decent parts. I am using them as a replacement for the marked-for-obsolescence VN5E010AH. I have a couple thousand of them right now because.... I could buy them. Supply is *extremely* limited.
The Weurth terminals are also awesome. They're very well designed. I think I am using a M5 one? Availability is kind of icky sometimes. TME seem to do a very good job of stocking them, if you don't mind shipping from Europe.
- Slack: Dave B.
- Contact:
Re: PDM info dump
Another source of high-current lug stuff is lugsdirect.com
They have a lot of bizarre and interesting parts.
I've tried some of their "SMD" parts (i.e. https://lugsdirect.com/B2C-PCB-SS-Surface-mount-tech-2-14AWG-115A-PCB-terminal.htm ) and have found them to be too easy to break off PCBs in the course of securing wires.
The slotted/TH parts (i.e. https://lugsdirect.com/B6A-PCB.htm ) are very good quality. Great value.
Note: these are *hard* to solder with just a regular soldering iron. Even with a 100W professional iron, you need to do some pre-heating. The parts just soak up too much heat. Wave solder with a little pre-heat? Butter. Excellent coating.
Re: PDM info dump
Also older MC33984/MC33988 - dual channel direct or SPI control. AliExpress has them at fairly decent price.
- Github Username: opelpanfan
- Slack: Ben
Re: PDM info dump
ETA makes SCS200 PDM.
https://global.e-t-a.com/products/intelligent_power_distribution_systems/scsr_smart_control_systems/scsr_smart_control_systems_products/p/scs200/#downloadBlock1537
It is PDM without any brains, controlled by can messages.
Put together Google drive folder with datasheets, manuals and CanHacker TSK file.
https://drive.google.com/drive/folders/11gI0tNVzajWzPDMimf89P38gjWX73gq3?usp=sharing
Re: PDM info dump
open source design https://github.com/corygrant/DingoPDM_HW
Re: PDM info dump
Would a latest and greatest VN9008AJTR be cool on a PDM? Pretty available right now.
