4 and 8 port canbus hub
opelpanfan
Github Username: opelpanfan
Slack: Ben
Post by opelpanfan »
Hi
I made 4/8 port canbus hub with common power rail and canbus end terminator resistors.
The 4 port project can be found :
https://oshwlab.com/b.brazdziunas/can-hub-mini
s-l1600 (1).jpg (218.47 KiB) Viewed 3494 times
The 8 port project can be found :
Can be used as all 8 ports on one bus or set two independent busses with independent or shared power rails.
Personally, I use 8 port hub for two-speed can busses (250kbps and 500kbps), 250kbps bus use 5v power rail where 500kbps use 12v power rail.
Zeiss
Github Username: HeinrichG-V12
Re: 4 and 8 port canbus hub
Post by Zeiss »
Ohhh, very nice stuff, thank you very much for that!
The wire connectors are this: click me, correct?
Regards,
Heinrich
My GitHub
Zeiss
Post by Zeiss »
Thank you very much!
Regards,
Heinrich
My GitHub
