Hardware status
Posted: Tue Nov 12, 2013 3:20 pm
pretty outdated post please see https://rusefi.com/ for better info
We are using stm32f4discovery as the main processing unit plus a couple of status LEDs and a reset button. Some boards are available for sale, see https://github.com/rusefi/rusefi/wiki/Hardware
See https://github.com/rusefi/rusefi/tree/master/hardware#user-content-modules
Pinout as google doc
Known to work:
Frankenso - our best ECU board so far!
64 pin 176122-6 ECU connector board
121 pin connector 368255-2 ECU connector board
analog input board - http://www.ti.com/product/lmv324
6 channel injector driver (also capable of driving ignition module/fuel relay/IAC)
CAN module
Project Frankenstein - full ECU shield
HIP9011 module
high side and low side driver module - TC4427
high side power switch - PowerSSO-24 & another high-side board on the same thread
breakout module
Communication module
12 channel analog board
12 channel injector driver
VR MAX9926 + knock module op/amp
power supply
stm32f4 MPU brain board 100 pin
DDPAK breakout (ignition IGBT)
38 pin NGC connector
72 pin Mazda connector
35 pin TCU connector
68 pin VW connector
Testing in progress
VR board MAX9926
Thermocouple input
TLE6240GP module - integrated low side switch
TLE6244 - larger integrated low side switch
stimulator board
stm32f4 MPU module LQFP 176
stm32f1 MPU module LQFP 48
Waiting for the board to arrive:
Looking for a volunteer to order new revision:
154 pin 284617-1 ECU connector
Work in progress:
Looking for help with a number of other modules:
electronic throttle body module
55 pin connector
MAP sensor module MPX
Not our stuff
stm32f4discovery dev board
Where to get these PCBs?
We are an open source project so all the hardware is available to be public, WITHOUT WARRANTY, under the conditions of rusEfi license available at license.txt
So, the boards:
You can order them directly from http://oshpark.com/profiles/rusefi or you can take the 'gerber' files and order them from any other PCB manufacturer
You can order some of the boards at our store @ Tindie
2015 status:
v3: Frankenstein:
Known to work:
CAN module
HIP9011 module
breakout module
power supply
68 pin VW connector
Testing in progress
VR board MAX9926
Thermocouple input
stimulator board
Work in progress:
55 pin connector
Not our stuff
So, the boards:
2015 status:
v3: Frankenstein:
