Proteus no Logging sd card
WOOL
Post by WOOL »
The problem is that there are no logs on the card. Despite the fact that I can physically see the card when I first connect it via USB. I created a log with a DEBUG SD Card and I don't see the logging file entries
Tune https://www.rusefi.com/online/view.php?msq=1564
Logs https://www.rusefi.com/online/view.php?log=1312
WOOL
Re: Proteus no Logging sd card
Post by WOOL »
the problem is solved, the problem was in the NTFS file system. After reformatting the card to FAT32, the problem was solved. now Proteus keeps logs on SD CARD
