rusEFI for GM Ecotec 4cylinder LSJ
Posted: Fri Sep 27, 2024 2:15 pm
Hi rusEFI Forum,
quick introduction. I am one of over 500 DF Goblin Kit https://dfkitcar.com/ owner. A car which is based on the Chevy Cobalt. Myself, I am a tinker, I love open source and helped with development of several projects if time allows. My programming hobby career started over 20 years ago with assembler and a deep understanding of microcontroller and ended up with self made Android apps
A popular engine in the Goblin is the LSJ which is a 2.0L supercharged with electronic Throttle Body and operated with the P12 ECU. The P12 ECU has several shortfalls and is not well supported by HP Tuners. Here is an overview of the different possible engines in the car. http://dfkitcar.com/forum/index.php?threads/making-hp-lnf-lsj-le5-lap-vs-l61.2309/post-90705
I started to a project to get an aftermarket ECU fitted to the engine. I ended up with the rusEFI as it seems to be the most promising.
Some key features for me would be:
Connection of the rusEFI to the current wiring harness without repining the plugs on the engine harness.
I want to be able to switch between the P12 and the rusEFI in less than 30min.
There is a way to connect a E67 ECU to the LSJ and I was wondering if we could use the E67 as a basis for that. I created the following table which outlines the P12 connectors, the E67 connectors which is in another engine and the E67 rusEFI. It turns out that this is not possible and would require repining of the harness.
https://docs.google.com/spreadsheets/d/1b8G7iBvuqbo4P1Lx2BbFZxI-32h6GhMSpjYO4CPKE4Y/edit?usp=sharing
Right now, I am thinking of making an PCB adapter which connects to a standard rueEFI.
My first question would be: Which is the best rusEFI to start with?
Once a rusEFI is selected, I can make a wiring diagram and develop the PCB to connect the engine harness to the rusEFI.
Any help is appreciated.
