short intro: I'm Detlef from Germany driving a BMW R100 (1000cc, carburator based boxer engine) from 1982 and my plan is to replace the standard ignition system by a DIY ECU to be able to better control the ignition timing and probably add a map sensor later.
So as a newcomer to rusefi, I have a few questions right off the bat regarding NANO's dumb coil support. If I could have found some answers by RTFM, I apologize in advance
About the project: I would like to equip my 1982 BMW R100 motorcycle (boxer/flat twin engine, wasted spark, a dumb inductive coil with two spark plug outputs, carburetor) with a DIY ECU and came across the NANO ECU.
Now my questions: Are there any specifications for the coil in terms of primary resistance, dwell time, etc. so that it works well with the NANO? How much current can the NANO's dumb coil drivers (IGBT) handle? And probably a beginners questions: Do ECU's dumb coil terminals always switch to ground?
And last (for this message) perhaps there is already some experience with a BMW motorcycle and the NANO ECU. I would of course appreciate any feedback.
Many thanks in advance for any feedback.
Detlef
