breakout module
Posted: Thu Jan 30, 2014 2:57 pm
This is a harness extension/T-junction utility board. WIth this board, you can have two output wires for each input wire, and turn each individual output wire using either a jumper or a mini fuse.
BK-6013-ND mini blade fuse holder is used - same thing as http://www.aliexpress.com/item/SL-506Pmini-blade-auto-fuse-block-SL-506P-mini-blade-auto-fuse-holders-CQ-122-FCB/446002696.html
The board is 10x10cm
Schematics of each half of this symmetrical board: https://svn.code.sf.net/p/rusefi/code/trunk/hardware/breakout_board/pin_board_1.pdf
SVN repository
breakout_board.zip
http://rusefi.com/wiki/index.php?title=Manual:Hardware:Breakout-Module/en
Ideas? Comments?
SVN repository
breakout_board.zip
Ideas? Comments?
