[info] Manufacturing options
russian
Soldering skill: yes
Coding skill?: yes
Post by russian » Wed Feb 19, 2014 9:56 pm
So far I have used:
http://oshpark.com/- $5 per square inch, free shipping from US. Great options to try tiny modules, not an option for larger boards due to price. No assembly.
http://www.seeedstudio.com/service/ $25 for 10 pieces 10x10cm board + shipping, 5 cents per SMD pin. Hoping to get Frankenstein with some components assembled by them pretty soon. Cons: fairly limited Open parts library of components they would use for assembly.
russian
Coding skill?: yes
Re: Manufacturing options
Post by russian » Wed Feb 19, 2014 10:05 pm
Today I have learned about another Chinese company: http://smart-prototyping.com/Prototypin ... bling.html
They have pretty good reviews, per SMD pin fee is higher and minimal assembly order is higher, but they have a full 0805 component book and they source parts for an extra fee without a 100pcs minimum. The PCB cost is the same as seeedstudio.
hasse.69
donator
donator
Post by hasse.69 » Fri Feb 21, 2014 8:03 pm
russian
Coding skill?: yes
Post by russian » Fri Feb 21, 2014 8:18 pm
hasse.69 wrote:Could this be something?
http://www.alibaba.com/product-gs/35924 ... mples.html
Do you want to download https://svn.code.sf.net/p/rusefi/code/t ... gerber.zip unzip remove "assembly instructions" files to reduce confusion, zip it back and ask them for a quote say for 30 pieces? :)
hasse.69
donator
donator
Post by hasse.69 » Fri Feb 21, 2014 10:58 pm
Done that.X2
X3
X4
hasse.69
donator
donator
Post by hasse.69 » Sat Feb 22, 2014 10:00 am
request sent to:
http://www.sunsoartech.com/
http://yhpcb.en.alibaba.com/
http://sky-macau.com/
http://pcb.hqew.net/
If they have additional questions i will ask here.
Hasse.
Post by kb1gtt » Fri Feb 28, 2014 7:56 pm
Seems people are even using e-bay for proto PCB assembly services http://www.ebay.com/itm/PCB-Manufacture ... 19cd57a472
hasse.69
donator
donator
Post by hasse.69 » Sat Mar 01, 2014 9:10 pm
That is one of the vendors i´ve sent a request to.
Post by kb1gtt » Sat Apr 19, 2014 1:02 pm
Did we ever hear back from any of the above inquires?
I also recently discovered http://www.elecrow.com/services-c-73/pr ... p-366.html which seems to be almost the same as SeeedStudio's service.
Nobody
Post by Nobody » Wed May 28, 2014 9:46 pm
If made in the USA means anything, then http://www.4pcb.com/bare-bones-pcbs/ind ... MgodTxYA2w been very happy. Know it's not the cheapest place.
UnaClocker
Post by UnaClocker » Thu May 29, 2014 2:30 am
http://www.smallbatchassembly.com/ This place is hobbiest friendly, much like OSHPark and OSHStencils, if you need to have a batch of boards with tiny SMD stuff assembled, it might be a viable option.
Brian from Tacoma, WA
84 Dodge Rampage
01 PT Cruiser
Post by kb1gtt » Mon Dec 26, 2016 7:42 pm
Just a note, elecrow does PCB assembly.
https://www.elecrow.com/services/pcb-assembly.html
russian
Coding skill?: yes
Post by russian » Tue Sep 19, 2017 1:23 am
Another pretty cheap option https://jlcpcb.com/quote
russian
Coding skill?: yes
Post by russian » Fri May 10, 2019 1:55 pm
Googling "why is jlcpcb so cheap" gives us an interesting discussion https://www.reddit.com/r/PrintedCircuit ... to_others/ with the OSHPark guy teaching us new words like Tg130, Tg140 vs Tg180.
I am not making a huge secret from the fact that current source of Frankenso PCBs and assembled boards is not exactly perfect - we've definitely seen a couple of PCB defects. And that's while being quite more expensive than jlcpcb.
Actually @ has an assembled board which gave me some magic sparks on first 12v power on.
Old Grey
Post by Old Grey » Sat May 11, 2019 10:09 pm
In the past year I have read 3 cases of traces falling off PCBs when a burnt component was changed, but I don't know who the PCB manufacturer was. The 2 layer JLCPCBs that I got recently didn't lose any traces, and I applied a lot of heat fixing the FUs you didn't see, but I don't know about complicated stuff like 4 layer.
russian
Coding skill?: yes
Post by russian » Thu Jun 06, 2019 11:53 pm
The assembly shop I am using currently does not have a website?! Maybe they are just a small one person broker I guess/ https://twitter.com/tingriverpcb
