[info] 64 pin 176122 ECU connector board
Re: 64 pin 176122 ECU connector board
TurboTurd wrote:
Fri Sep 18, 2020 2:35 pm
Hi all,
I have found a seller on eBay selling a version of this board, that I wish to use in my Mx5 ecu build.
Could anyone tell me what the layout of the 'output' pins on this board are for? I.e. what is the intention for connecting this to your main ECU board? Other adapters I have seen for different ECU connectors use a standard 40 pin IDC connector for this purpose.
first post in this thread has complete files with the complete layout.
all our adapters are designed for wires soldered to the board, they do not follow any specific footprint. I believe we are not huge fans of 40 pin IDC in engine control applications but I am just a software developer.
Any volunteers to add silkscreen to the back side of the board? Current 0.2 revision is lacking in usability because of that.
We have 0.3
Neobob22
Post by Neobob22 »
Hi
Bought 2 of this almost perfect pcb for my use about 5 years ago (yeah I'm pretty lazy upgrading something which worked but now I'm in a hurry and get a new ecu almost ready to send) and I'm encountering an issue :
Wire don't go through the holes, I have to shave more than half the strains...
I've designed and finished an encolure, weld the connector, rev 0.3 looks better but will not match my enclosure.
-> any tips to use such 0.1 rev ??
Maybe some terminal to crimp with a straight thin "needle" that can be weld on it ?
Can you confirm the holes diameter ?
Thanks in advance, kind regards ;)
Neobob22
Post by Neobob22 »
From what I was able to measure, ordered some mill-max 0380 and will have a try.
Neobob22
Post by Neobob22 »
Did a try, works pretty well but I may have some skills lack and also designed a too tight housing so get some stress on some wire an lose some connection.
Finally, I don't need the double row for each pin, but will enjoy to have bigger holes to directly weld wires on the pcb and limit issues...anyone willing to make an update or will I try my first pcb design for such purpose ??
I really wanna avoid welding wire directly on connector pins :mrgreen:
