[info] CAN bus: RX8 cluster
While Chrysler bus is work in progress, my plan C was to use a 2004 RX-8 gauge cluster
It's amazingly beautiful
It's pretty cheap
It seems to be kind of documented
[video][/video]
It's pretty cheap
[video][/video]
Re: CAN bus: RX8 cluster
Does the display have the termination resistor internal to it? Do you measure 120 ohms across terminals J and L? Also do you have a 120 ohm across your end? You will need the 120 ohm at each end of the bus. Your bus is short. If you need to add a 120 to the display, you could probably get by with two paralleled 120's at your end.
Just checked - yes the cluster has 120 ohm between the CAN wires, and so does my transmitter end.kb1gtt wrote:Does the display have the termination resistor internal to it? Do you measure 120 ohms across terminals J and L? Also do you have a 120 ohm across your end?
speed inconsistency? btw, could it be so that discovery uses 3.3V levels while the cluster requires 5V or even higher?
Is your reference clock XTAL based? CAN can be very picky about having a proper accurate clock.
I am using stm32 native, behind the scene CAN peripheral. I am pretty sure it's just some stupid bug, I simply need someone to review the code and spot something off.kb1gtt wrote:Is your reference clock XTAL based?
Will try googling the exact wiring later, there must be info on which CAN wire is which.
In order for the dash to work correctly, packets have to be sent regularly (20-500ms)
Sure, the code does that.puff wrote:In order for the dash to work correctly, packets have to be sent regularly (20-500ms)
chThdSleepMilliseconds(engineConfiguration->canSleepPeriod);
btw, have you tried debugging it with logic analyzer? and i still couldnt find if 3v and 5v devices are compatible..
I am not sure this 3v/5v applies here. CAN is CAN, at least I hope sopuff wrote:and i still couldnt find if 3v and 5v devices are compatible..
can't get it what it means - high impedance, low impedance... but when you look at the transceiver pinout, you'll see that it is powered either from 5V or from 3V, which seemingly implies that this voltage levels could be found on the can bus. How does the transceiver sense the lines?
Have you checked what's going on with logic analyzer?
Turned out wrong data in the packet - wrong offsets, also this cluster uses different byte order.
[video][/video]
[video][/video]
If anyone is interested - I've paid $30 for the cluster with the piece of harness, I was risking - it has mounting taps broken off and was being sold as "for parts"
Normal eBay price seems to be about ~$50 for cluster and ~$20 for the piece of harness
[video][/video]
just got it with harness ~ $40
turns on, with lights.
tomorrow gonna try it with rusefi.
mine has the side gauges reversed: oil stuff is to the left, fuel and temp - to the right.
need to know what is the second, bigger connector - what are these wires.
neet more info on fuel gauge.
need to figure out the odo thing.
people say, CLT needle doesn't react to the actual fluctuations in temerature once it reaches the working conditions, which is weird. the same reportedly refers to oil pressure - it's either no pressure, or normal pressure.
what are these three interior light system wire in the smaller connector?
what is d) (brn/blk) wire in the smaller connector?
how do i switch it from mph to kmh?
is there a chance to feed some other switched signals to this cluster over CAN?
e.g. oil pressure switch?
traction control (I'd like to indicate diff lock condition instead)
parking brake?
coolant level?
could it switch on the battery light if the engine is running (rpm>0), and the voltage is lower than 13V?
could it switch on the check engine light via CAN, not a separate contact?
are there any chances to implement trip meter? (though, involves too many CAN messages, and probably requires some really fancy maths)
will it feed speed signal from rusefi?
parking brake?
coolant level?
If I understand this correctly,
all these values are actually hardware coded - not taking the real-time values
isn't it 0.1 kms?
commonTxInit(CAN_MAZDA_RX_STATUS_2);
txmsg.data8[0] = 0xFE; //Unknown
txmsg.data8[1] = 0xFE; //Unknown
txmsg.data8[2] = 0xFE; //Unknown
txmsg.data8[3] = 0x34; //DSC OFF in combo with byte 5 Live data only seen 0x34
txmsg.data8[4] = 0x00; // B01000000; // Brake warning B00001000; //ABS warning
txmsg.data8[5] = 0x40; // TCS in combo with byte 3
txmsg.data8[6] = 0x00; // Unknown
txmsg.data8[7] = 0x00; // Unused
txmsg.data8[0] = 0x98; //temp gauge //~170 is red, ~165 last bar, 152 centre, 90 first bar, 92 second bar
txmsg.data8[1] = 0x00; // something to do with trip meter 0x10, 0x11, 0x17 increments by 0.1 miles
txmsg.data8[2] = 0x00; // unknown
txmsg.data8[3] = 0x00; //unknown
txmsg.data8[4] = 0x01; //Oil Pressure (not really a gauge)
txmsg.data8[5] = 0x00; //check engine light
txmsg.data8[6] = 0x00; //Coolant, oil and battery
txmsg.data8[7] = 0x00; //unused
sendMessage();
Что-то берётся настоящее, но много не берётся. У меня точно не будет рук делать - принимаю патчи и улучшения!
float kph = getVehicleSpeed();
setShortValue(&txmsg, SWAP_UINT16(getRpmE(engine) * 4), 0);
setShortValue(&txmsg, 0xFFFF, 2);
setShortValue(&txmsg, SWAP_UINT16((int )(100 * kph + 10000)), 4);
вся процитированная тобой часть стоит внутри #if - то есть выполняется только если в системе имеется датчик скорости?
то есть без датчика скорости автомобиля на панели приборов даже обороты отображаться не будут?
плюс почему-то 144 и 154 строки дублируют номер пакета, и после формирования первого пакет так и не отправляется...
вот патчик для температуры и миганий лампочками. правда, собирать не пробовал...
а для одометра нужно будет, наверное, переделать тот коэффициент датчика скорости в более удобоваримое значение (сколько импульсов на метр/километр?), и из кода датчика скорости делать колбеки, что ли? причем только в случае, если выбрана приборка мазды? как иначе заставлять его отправлять can сообщение с меняющимся вторым байтом каждые 33 метра пробега?
- rx8.patch
- (546 Bytes) Downloaded 803 times
зато теперь патч, который собирается)
- rx8.patch
- (978 Bytes) Downloaded 749 times
Any chance to make this a github pull request? See http://rusefi.com/forum/viewtopic.php?f=13&t=325&p=25517#p25517puff wrote:зато теперь патч, который собирается)
Congrats @ on https://github.com/rusefi/rusefi/pull/407
CANbus is differential but the signal level is only around 2V so it doesn't matter if its 3v3 or 5v supply. The common mode voltage does matter though so you need a good common ground.puff wrote:can't get it what it means - high impedance, low impedance... but when you look at the transceiver pinout, you'll see that it is powered either from 5V or from 3V, which seemingly implies that this voltage levels could be found on the can bus. How does the transceiver sense the lines?
didn't know that - hadn't checked the voltage with the scope.
so, good ground is a must, even for CAN
