idle controller ignition
It's all about the code!
rus084
Post by rus084 »
What about the idle speed regulator by adjusting the ignition timing?
I did it with the help of "pid.cpp" . i right?
what factors install by default?
+static msg_t iiThread(int param) {
+	(void)param;
+	chRegSetThreadName("Idle Curve thread");
+	static Pid idling_pid(engineConfiguration->idlePfactor,engineConfiguration->idleIfactor,engineConfiguration->idleDfactor,engineConfiguration->minIgnCurve,engineConfiguration->maxIgnCurve);
+	while (TRUE) {
+		chThdSleepMilliseconds(boardConfiguration->idleThreadPeriod);
+		if (!isCranking()) {
+		curve= idling_pid.getValue(engineConfiguration->targetIdleRpm,getRpm(),boardConfiguration->idleThreadPeriod);
+#if defined __GNUC__
+	return -1;
+#endif
+void initIdlignInginion(void) {
+	chThdCreateStatic(iiThreadStack, sizeof(iiThreadStack), LOWPRIO, (tfunc_t) iiThread, NULL);
+float getIgnCurve() {
+	return curve;
+int isIdleMode(void) {
+	if (getTPS(engineConfiguration) > engineConfiguration->maxIdleTps) {
+		return true;
+	return false;
Re: idle controller ignition
Did you get it idle your engine?
rus084
Post by rus084 »
no , i need discovery board
