[help needed] rusEFI console angle do not fit with trigger event...
It's all about the code!
marauder1441
Post by marauder1441 »
Hi,
I made some modification on rusEFI to get it working on a DRZ400. During my test, on a trigger event mapped to 718 degree appear in engine sniffer to 5.45deg. All the degree in engine sniffer are offset... But if I take a look to ignition in cranking mode setuped to 16deg charge angle and timing at 0deg, I get the falling edge on ignition at 6.61deg. So the position of the pulse isn't too bad, it's near of the place it's supposed to be relatively to primary trigger position.
Those error seem to be on display only. But how can I do to validate if it come from smt32 board or rusefi console?
Thanks
Re: rusEFI console angle do not fit with trigger event...
Let's begin from the beginning, right now I have no idea what you have and where you are.
Do you have any hardware? Can you take any pictures for us to understand where you are?
Can you please share any screenshots of the console showing engine sniffer tab?
It looks like you are looking to adjust either your globalTriggerAngleOffset or triggerShape.tdcPosition or ignitionBaseAngle, or a combination of those. And I need to apply consistent naming to these four variables which define absolute and relative angle positions.
