Can someone explain what this setting is/does in Tuner Studio?
Please.
Analog Divider (coef)
Re: Analog Divider (coef)
Good question!
This is the voltage-divider for the analog inputs.
Ideally this should be in the board-configuration, and be removed/hidden for users
stm32 has 3v ADC. most or all rusEfi boards have opamp input circuitry with a divider, often ratio is 2 or 1.67
Questions like this are really useful to see which things that makes confusion.
We can remove/hide these settings in TS, and set it in the board-configuration.
A user dont really need to change these settings
We have the mechanism to hide such settings from TS project, I've just done so for microRusEfi
https://github.com/rusefi/rusefi/commit/c553877d3d375a068a3e62ba58685dc51f142ecd
AndreyB wrote: ↑Sun Mar 01, 2020 2:22 pmWe have the mechanism to hide such settings from TS project, I've just done so for microRusEfi
Great
so how to use it? i have used it to adjust for my voltage divider. if for example i have 5 volts divided down to 2.5 what would my setting be for a full scale 0-3v on the MCU.
what is the value the Analog Divider representing?
Just modified the description, new bubble description reads:
Ratio/coefficient of input voltage dividers on your PCB. For example, use '2' if your board divides 5v into 2.5v. Use '1.66' if your board divides 5v into 3v.
