SD card in SDIO mode
It's all about the code!
Piter.W
Github Username: Piter.W
Post by Piter.W »
I am working with the STM32F407 board. Same as the link: https://github.com/mcauser/BLACK_F407VE. Is it possible to use an SD card in SDIO mode? (The board does not support SPI for SD CARD). Do you need to change anything in the FW? I found this link but it doesn't tell me much https://github.com/rusefi/rusefi/issues/683. Thank you.
Re: SD card in SDIO mode
Yes, the firmware is compiled for either SDIO or SPI. You need to define EFI_SDC_DEVICE when compiling, and configure the pins to the correct alternate function in board.h.
Piter.W
Post by Piter.W »
Thank you. I can see that board.h file is only in hellen, prometheus, kinetis and subaru config folder. If I would like to compile the firmware with any other board can I just copy board.h file to that folder?
Thank you
