[help needed] The stepper motor is not working
It's all about the code!
1204257363@qq.com
Github Username: jiafu400
Post by 1204257363@qq.com »
I used rusefi plate throttle with stepper motor on the motorcycle, and set the stepper motor function Dan on the debugging software. The motor can only work one-way and does not return. What is the problem
Re: The stepper motor is not working
what hardware? please post tune, see http://rusefi.com/s/questions
1204257363@qq.com
Firmware μsEFI v20210106@28903) EFI Simp uses 4988 driver
1204257363@qq.com wrote:
Thu Jun 23, 2022 3:51 am
what is μsEFI ?
today is end of June of 2022 why January of 2021 firmware?
what is EFI Simp?
can you post your tune and log at https://rusefi.com/online ?
1204257363@qq.com
I'm really sorry for the wrong expression. Now the stepper motor problem has been solved by updating the latest firmware. Now I find that the maximum speed limiter can only be 12750RPM, and the maximum speed of my motorcycle carburetor is 18000.
that's a defect https://github.com/rusefi/rusefi/issues/4298 give me a couple of days to fix
RPM limit fixed now please try latest snapshot version
1204257363@qq.com
Tested, OK
1204257363@qq.com
Does it support Bluetooth wireless connectivity? USB connection is easy to drop when the engine is working
Yes, but it would be worse.
Please start providing much more info. Pictures of hardware, pictures of wiring, etc etc.
1204257363@qq.com
The setting of ejection can only be default. Other options will be automatically restored to "Simultaneously" after the ECU is powered off. Other options cannot be saved
Please start a build thread with vehicle and hardware photo.
Please use https://rusefi.online to share full tune
