[help needed] VVT OUTPUT 1 Problem (MicroRusEFI)
It's all about the code!
gustavoportilla
Post by gustavoportilla »
Hello, I am experiencing a problem with the VVT ​​output 1 on the microRusEFI board. After a few accelerations, the VVT ​​output 1 remains activated, the pin used is pin 7 (Low Side 1). I have also tested with double VVT ​​output using pin 3 (Low Side 2) and the VVT ​​output 2 works correctly, there are no problems.
gustavoportilla
vvt out.JPG (221.78 KiB) Viewed 2616 times
PID config.JPG (71.56 KiB) Viewed 2616 times
Re: VVT OUTPUT 1 Problem (MicroRusEFI)
https://github.com/rusefi/rusefi/wiki/rusEFI-Quick-Start-PDF is asking for logs
Not much life on the forum either way :(
gustavoportilla
Hi, I'm sending records
2024-12-25_14.37.37.rar
(2.15 MiB) Downloaded 56 times
Last edited by gustavoportilla on Wed Dec 25, 2024 7:45 pm, edited 1 time in total.
gustavoportilla
AndreyB wrote:
Sun Dec 22, 2024 3:43 pm
(2.15 MiB) Downloaded 54 times
