this is a feature that's pretty standard in most standalone ECUs, observe:
it is a standard interface in TunerStudio, some may be familiar with it.
in this implementation i added ALL of the GPIO ports on my lqfp208 board, and 3 connectable conditions:
this particular one checks for 7th bit in canButtons18 variable, which is a combination of my canbus toggleable buttons from previous post, the condition is "AND 64", which is basically " & b0100 0000", it could check for more than one bit being set
here is a setup for this demo:
3 ports i picked as they weren't used, but tested, and routed to my bench board
https://youtube.com/shorts/7QgUez-ZSdQ
and you can see them light up when i hit a button on the keypad, keypad is connected to hardware that sends the keycode over canbus to the ECU, ecu toggles a canButton on/off (in this case button 6 7 and 8)
which results in LED turning on and off
the following setup is for RPM-based condition with hysteresis:
and video of it in action, twisting the RPM knob on the simulator
https://youtube.com/shorts/-GI-mWJbn9c
each output has 3 conditions
each condition can be:
and conditions are tied together with more logic links:
they are executed in order they appear, allowing for:
1
1 AND 2
1 OR 2
1 AND 2 AND 3
1 AND 2 OR 3
1 OR 2 OR 3
1 OR 2 AND 3
it breaks if an output is already assigned, as expected.
programmable outputs - demo
gurov
- Github Username: ggurov
- Slack: ggurov
- Contact:
1994 6speed supra turbo [ single turbo/1000cc ID/twin fuel pumps/bc2 262 cams ]. J&S safeguard for knock , UAEFI / 407 disco with rusefi / AEM EMS v2 / MS3pro PNP / Speeduino (mega2560 / teensy41 / stm32f411)
2020 BMW X3m - bootmod3 stage1
- mpgmike
Re: programmable outputs - demo
So this is like creating "virtual" ports and/or conditions? No additional hardware or wiring involved? Intriguing! Thank you for sharing that incredibly useful information.
gurov
- Slack: ggurov
- Contact:
they're hardware ports on the CPU, connected to other hardware, injectors /ignition/generic mosfets, etc.
something that should've been there for a long time, just wasn't a priority
Adam_86
- Github Username: Adamg-86
That is so awesome, we need that in the firmware. I wanted to control boost level from my display, this would solve it. Good job
gurov
- Slack: ggurov
- Contact:
getting close to having it actually behave a bit more user-friendly with board-speciffic names.
