Are there any documentation available how crankshaft position is calculated and how ignition callback is generated in current software ?
I'm trying to go through the software to get the idea how is it designed.
Engine position
Re: Engine position
http://rusefi.com/docs/html/
I would be happy to extend this article, so please read & ask questions.
mpeski
Re: Engine position
Ok, so is the ignition event only occurring on trigger interrupt ? I mean, can ignition be adjusted between trigger pulses ?
Re: Engine position
Sure it can. I've just expanded the last paragraph, it now reads:
At some point I would need a native speaker to fix my broken English...So, for this particular sensor the most precise scheduling would be possible if we schedule coil charting as '85.6 degrees after the 600 degrees position sensor event', and spark firing as '10 degrees after the 690 position sensor event'. Considering current RPM, we calculate that '10 degress after' is 2.777ms, so we schedule spark firing at '2.777ms after the 690 position sensor event', thus combining trigger events with time-based offset.
mpeski
Re: Engine position
Ok, perfect. One more question. Time in the example, 2.777 ms, when is that calculated ?
Your English far better than mine
Re: Engine position
2.777 ms is calculated within the trigger event interrupt handler when we know that this trigger event needs to schedule an output signal.
Check the handleSparkEvent method @ http://sourceforge.net/p/rusefi/code/HEAD/tree/trunk/firmware/controllers/trigger/main_trigger_callback.cpp#l117
At least I hope my Russian is better than yours.
mpeski
Re: Engine position
I think I got the picture now, looks good.
...more questions to come...
