Compile error using make or Eclipse
phiatt
Post by phiatt »
While trying to compile the source code, I get this error;
Compiling chschd.c
ChibiOS3/os/rt/src/chschd.c: In function 'wakeup':
ChibiOS3/os/rt/src/chschd.c:290:5: error: this statement may fall through [-Werror=implicit-fallthrough=]
     chSemFastSignalI(tp->p_u.wtsemp);
ChibiOS3/os/rt/src/chschd.c:294:3: note: here
   case CH_STATE_WTCOND:
cc1.exe: all warnings being treated as errors
make: *** [ChibiOS3/os/common/ports/ARMCMx/compilers/GCC/rules.mk:218: build/obj/chschd.o] Error 1
Has anyone seen this before? This happens with regardless invoking make from command or in Eclipse; windoze or Linux.
Re: Compile error using make or Eclipse
Eclipse is an IDE, it's like a cool notepad.
make is build automation tool.
it looks like the error you are publishing comes from a compiler. which compiler? are you building firmware or simulator?
phiatt
Post by phiatt »
Yes I am aware, Thank you for the clarification.
I am using gcc-arm-none-eabi-7-2017-q4-major.
phiatt
Post by phiatt »
I apologize, building firmware.
Thank you for reporting https://github.com/rusefi/rusefi/issues/517 !
Looks like a new option "-Wno-error=implicit-fallthrough" should be specific in Makefile - see https://github.com/rusefi/rusefi/commit/a8aaca866d94d673eaddd3b4d32cbbacf92bb7a0
I guess I should migrate to latest compiler on all my devices and make this official, but not today.
phiatt
Post by phiatt »
Cool, Thanks for the help. I'll give it a go.
