Miata VVT trigger sim
mazdee
Post by mazdee »
Hi.
Are the settings for engine type 47 the ones to use? (crank primary, no secondary and vvt on the cam)
i get 1/2 commanded RPM displayed in console ? vvt angle does change if force random inputs on the cam input but it isnt clear if the simulator is giving out any triggers on the cam channel?
i will try and scope it tomorrow and see
mazdee
Re: Miata VVT trigger sim
Post by mazdee »
nb only using bare stm32f407
At the moment trigger simulation logic is not aware of VVT
In case of Miata VVT the work-around is a special trigger only for simulation but it requires two rusEfi instances - one running TT_MAZDA_MIATA_VVT_TEST trigger just to produce both signals, the other to consume signals
https://github.com/rusefi/rusefi/issues/566
See also https://github.com/rusefi/rusefi/commit/863701ef905b899fe61a5acf8c26c08dc3dd5447
mazdee
Post by mazdee »
thanks for quick reply!
im reasonably sure i can just connect my sensors now and see what comes out the other end :)
i was going to use an mpx4250 for map but it would need stepping down. does there exist a MAP sensor that runs on 3.3v ?
mazdee wrote:
Sat Feb 03, 2018 5:12 pm
Want to start a thread about your car with pics and stuff? MAP sensor voltage is offtopic for "Miata VVT trigger sim" thread. Sorry for my kind of crazy :)
mazdee
Post by mazdee »
no problem :)
