[help needed] Grabbing values over CanBus
mazdee
Post by mazdee »
Hi all.
I would like to grab some values from rusEFI to print on my display. do I need to send a request or can I just listen in? what nitrate and stuff should I use?
cheers
Re: Grabbing values over CanBus
which exactly?
mazdee
Post by mazdee »
I would like to read vvt position on my display and (if it's doable) receive map from gpio (akthough mpx4250s are quite cheap so no biggie)
the other alternative is to send serial commands and read in what comes back - not sure what the command is on rusefi though .
mazdee
Post by mazdee »
ok I have found the obd2 stuff so I'll have a read. looks like there are only a few pids but good exercise to read those I guess :)
CAN support is a bit experimental and limited. As for serial port see https://github.com/rusefi/rusefi/blob/master/firmware/console/binary/tunerstudio.cpp
mazdee
Post by mazdee »
Thats great. seem to be returning some values sending an 'O' ill let you know how it goes.
