Compiling Error
Compiling Error
I just installed the tools needed to be able to edit and compile my own version of the RusEfi software but when I try to make a build i'm getting this. Any help?
- compile error.PNG (120.66 KiB) Viewed 4616 times
Re: Compiling Error
Have you downloaded git submodules?
git submodule update --init
https://git-scm.com/docs/git-submodule
Re: Compiling Error
Sorry for the delayed response, haven't had much time to play around with setup since i originally posted.
So i found out why i had that previous error pop up. I had downloaded a copy of the rusefi software form github but it did not download the files in the ChibiOS4 and ChibiOS-Contrib folders, so when i built the project those files were missing.
Now, I cloned a copy thru git inside eclipse so all folders are present. But at build time I'm getting yet another build error:
I guess I got a little further this time. All this Git, Eclipse and ChibiOS stuff is all very new to me.
- eclipse compil error2.PNG (182.72 KiB) Viewed 4571 times
Re: Compiling Error
these options which compiler is complaining about were added in 2017 version of compiler. please upgrade your compiler
this is related to https://github.com/rusefi/rusefi/issues/517
Re: Compiling Error
PS: would be amazing if anyone adds a check into our makefile to check compiler version and to print error if compiler is too old. simulator was recently upgraded to require version 7 as well (different versioning on windows vs arm compiler)
@ maybe?
@ maybe?
