Compile for 144 pin CPU
Post by 960 »
I am trying to compile for 144 pin cpu.
I have edited rusefi_enums.h, but get error in auto_generated_enums.cpp.
What more needs to be changed?
Re: Compile for 144 pin CPU
Something is not right here. Same firmware runs in 100 and 176 pins boards as long as same base chip.
960
Post by 960 »
russian wrote:
Wed Feb 06, 2019 9:49 pm
In board configuration I have used GPIOF AND GPIOG.
Then i get errors.
When i click open declaration it opens rusefi_enums.h.
So I edited to get gpiof and g.
Should it work without editing anything at all?
Ohhhhh, now I see what you mean.
https://github.com/rusefi/rusefi/issues/688 created
960
Post by 960 »
russian wrote:
Wed Feb 06, 2019 11:35 pm
Did you find solution?
I get errors in this line:
const char *getBrain_pin_e(brain_pin_e value){
switch(value)
not handled in switch for all GPIOF and GPIOG
960 wrote:
Fri Feb 08, 2019 6:59 am
I need a solution which would work for everyone and that one has some complication, I hope to have the fix maybe within the next week or two. Definitely on my TODO list.
960
Post by 960 »
russian wrote:
Fri Feb 08, 2019 7:21 am
Ok, Thanks.
I thought maybe I was doing it wrong.
960
Post by 960 »
Would it be possible to split the Firmware into one for each CPU?
That way it would be easier to get a full overview.
