Page 3 of 4
Re: End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Posted: Wed Mar 02, 2022 12:43 pm
I would ignore the Hardware: F4 message it could be broken
https://github.com/rusefi/rusefi/issues/3973
please open case, please get unit into DFU mode with the hardware buttons if it seems not to respond
also latest snapsshot has relevant improvements please use
https://rusefi.com/build_server/rusefi_bundle_proteus_f7.zip file
Posted: Wed Mar 02, 2022 1:57 pm
by Zeiss
Attached is the log file with update to the latest daily build.
Result:
-> console doesn't crash anymore
-> no MSC devices (neither internal flash nor SD card)
I have not used the PROG button, there is everything purely via software.
Posted: Wed Mar 02, 2022 6:43 pm
by Zeiss
I've tried to flash the old firmware version, snapshot_20211114_215906_proteus_f7_rusefi:
1. boot into bootloader (PROG button pressed during power on)
2. full erase (stm32-full-erase.bat)
3. flash the firmware (stm32-flash-dfu.bat)
4. reboot
Neither flash nor SD card in explorer. Device manager says:
- grafik.png (5.2 KiB) Viewed 46178 times
Console connects the Proteus. but I get a warning:
- grafik.png (6.07 KiB) Viewed 46178 times
Is that normal?
LED status:
-> green on
-> blue is flashing
-> yellow is on
Posted: Wed Mar 02, 2022 6:56 pm
"flash CRC failed" is expected for first boot after full erase
Posted: Wed Mar 02, 2022 7:06 pm
by Zeiss
Behaviour before update:
after connect Proteus to PC I've got two drives in windows explorer:
-> one with rusefi_proteus_f7.ini on it
-> one with log files, my SD card installed in Proteus.
-> COM-Port for communication
After update:
-> no drives, neither SD card nor internal flash with rusefi_proteus_f7.ini
-> COM-Port for communication it there
Is the behaviour after update normal or is something wrong?
Posted: Wed Mar 02, 2022 7:23 pm
by mck1117
We turned off the "virtual USB drive" on F7 proteus to work around some other issues. You should still see the SD card.
Can you find your ECU in device manager with it set to "view by connection"?
- image.png (8.55 KiB) Viewed 46172 times
Hint: you can select the com port, then change to "view by connection" mode, and it'll auto expand the view to show the device.
I see this:
- image.png (28.97 KiB) Viewed 46172 times
Posted: Wed Mar 02, 2022 7:42 pm
by Zeiss
mck1117 wrote: ↑Wed Mar 02, 2022 7:23 pm
Okay, that explains it of course.
I see this:
- grafik.png (27.07 KiB) Viewed 46167 times
Posted: Wed Mar 02, 2022 7:46 pm
by mck1117
Right click "STMicroelectronics virtual COM port", uninstall, check the "delete driver" box, hit OK. Unplug ECU, replug ECU.
Posted: Wed Mar 02, 2022 8:10 pm
by Zeiss
Done:
- grafik.png (12.78 KiB) Viewed 46163 times
Thank you Matt, you are my hero!
And the next error, in TunerStudio (Version 3.1.08) during creating of a new project:
- grafik.png (14.2 KiB) Viewed 46163 times
Ideas?
Posted: Wed Mar 02, 2022 8:31 pm
by mck1117
Zeiss wrote: ↑Wed Mar 02, 2022 8:10 pm
https://github.com/rusefi/rusefi/pull/3974
Posted: Thu Mar 03, 2022 9:41 am
by Zeiss
After upgrading to the latest daily build (snapshot_20220303_003810_proteus_f7_rusefi), things are looking good now, even in TunerStudio.
Thanks Matt and Andrey for the quick help, you guys are awesome!
Posted: Sun Mar 20, 2022 3:11 pm
Posted: Mon Apr 18, 2022 2:45 pm
New top level menu 'view' now shows a lot, a LOT of sweet data!
No documentation as always and still a lot to do but a huge step forward in terms of monitoring
- image.png (28.92 KiB) Viewed 43604 times
https://github.com/rusefi/rusefi/issues/3614
Posted: Sat Apr 23, 2022 12:48 am
Posted: Fri Apr 29, 2022 11:38 pm
rusEFI snapshot has an incompatible change to calibration format, please plan your bump to snapshot accordingly.
Posted: Fri Jun 03, 2022 12:18 am
Posted: Mon Jul 04, 2022 2:34 am
Posted: Sat Jul 30, 2022 4:49 pm
There is now a way to lock your tune from reading!
https://github.com/rusefi/rusefi/issues/4243
I shall teach people how to unlock on the need-to-know-basis (evil laughter)
- image.png (245.66 KiB) Viewed 42054 times
Posted: Fri Aug 12, 2022 5:19 pm
Posted: Wed Sep 14, 2022 4:36 pm
Posted: Thu Nov 17, 2022 3:42 pm
Posted: Sat Nov 26, 2022 3:53 am
Posted: Thu Dec 01, 2022 4:13 pm
Posted: Sat Dec 10, 2022 4:06 am
Posted: Sun Feb 05, 2023 2:21 am
Posted: Tue Feb 07, 2023 3:03 pm
Posted: Sun Mar 05, 2023 4:52 pm
David has implemented Nightly for
https://github.com/rusefi/rusefi/releases
Open question to update documentation to explain what exactly does it mean
https://github.com/rusefi/rusefi_documentation/issues/427
Posted: Fri Apr 07, 2023 10:09 am
Posted: Wed Apr 19, 2023 5:52 am
Posted: Tue Apr 25, 2023 1:34 pm
