serial comunication problem
atntpt
Soldering skill: yes
Coding skill?: yes
Post by atntpt » Sat Apr 20, 2019 7:55 am
tunerstudio disconect after burn anything
console give me this
2019-04-20 08_49: EngineState: confirmation_writeconfig:11
2019-04-20 08_49: EngineState: !!!!!!!!!!!!!!!!!!!! BE SURE NOT WRITE WITH IGNITION ON !!!!!!!!!!!!!!!!!!!!
2019-04-20 08_49: EngineState: flash compatible with 10001
2019-04-20 08_49: EngineState: Reseting flash: size=20012
2019-04-20 08_49: EngineState: Flashing with CRC=248
2019-04-20 08_49: EngineState: Flash programmed in 163ms
2019-04-20 08_49: EngineState: FLASH_SUCESS
2019-04-20 08_49: EngineState: TS: ERROR: no second byte
2019-04-20 08_49: EngineState: TunerStudio size=356 / total=4241 / errors=5 / H=8 / O=2258 / P=200 / B=1
2019-04-20 08_49: EngineState: TunerStudio W=0 / C=25 / P=2 / page=0
using discovery micro usb works fine
russian
Coding skill?: yes
Re: serial comunication problem
Post by russian » Sat Apr 20, 2019 1:42 pm
This is a forever story :(
https://github.com/rusefi/rusefi/issues/766 low priority unfortunatelly
atntpt
Coding skill?: yes
Post by atntpt » Wed Apr 24, 2019 10:06 am
the thing is i have done some burns a couple days ago and TS never disconected now is always disconecting. is it random? also if hc05 is soldered usb stops working tryed a diode on BT module TX but still unable to use usb ..
atntpt
Coding skill?: yes
Post by atntpt » Wed Apr 24, 2019 5:08 pm
Also with lower baudarates fails less often
