Firmware bugs
Posted: Fri Jun 14, 2019 4:35 pm
by JRD McLAREN
I can't found any related thread about bugs in firmware.
So started one ...
Now I can try ver. 20190614 ..
and fill cylinders with fuel .. on cranking stage ..
inj.time 277.46ms .. and other high numbers ..
Re: Firmware bugs
Posted: Fri Jun 14, 2019 4:57 pm
We've recently made changes related to
https://github.com/rusefi/rusefi/issues/773
this is about unifying scale of corrections and adjustments. Right now we are debating what kind of announcement should be done at
https://rusefi.slack.com/messages/CJZ7LJFL1/stars/
Unfortunately we do not have a uniform opinion on how to approach such incompatible changes and the developer who did the change did not investigate user migration experience. I could be wrong and this could be totally unrelated.
Re: Firmware bugs
Posted: Fri Jun 14, 2019 6:28 pm
by mck1117
Can you share your .msq tune file? It's hard to diagnose without knowing what the configuration in use was.
Also, did you upgrade from a previous firmware version, or is this a fresh, blank configuration?
Re: Firmware bugs
Posted: Fri Jun 14, 2019 7:00 pm
by JRD McLAREN
I was upgrade from (working) previous version ...
(now is downgraded back)
As I'm understand it, it is not BUG, but it is change from #coef# to #percentage# ...
(or vice versa)
and TPS calibration is not working also ...
Re: Firmware bugs
Posted: Tue Jun 18, 2019 2:03 am
JRD McLAREN wrote: ↑Fri Jun 14, 2019 7:00 pm
This is probably fixed now
https://github.com/rusefi/rusefi/issues/805
