[help needed] rusEfI based on STM32F4 (Frankenso) for air-cooled small vehicles
Hi everyone!!
I got a rusEFI to control a small air-cooleed engine and I have all ready to run... except one thing.
Because of this engine is air-cooled, the CLT sensor can reach 200ºC-300ºC but when I open the tunnerStudio project to monitorize the EFI, when the CLT temperature is greater than 200ºC, CLT Gauge turn to 0.
I have read some messages from the forum to edit the config.ini file from the TunnerStudio project to change the upper limit and fix it at 350 ºC. I can change the gauges limits but I can't find a parameter to change the 200ºC limit.
How can I do it?
Thanks in advise.
How can I do it?
Thanks in advise.
Re: rusEfI based on STM32F4 (Frankenso) for air-cooled small vehicles
I've created https://github.com/rusefi/rusefi/issues/1914 to track this issue
if you please paste exact screenshots of how TunerStudio is handling things now for you and what are those limits affecting it would be easier for us to test our changes once we make those.
Thanks for help!!
For a better explain I tell you my configuration:
- 10k thermistor (with a bias pull up 2.49K resistor) wtih a voltage driver at the entry of the clt's ADC (PC2. STM32F407VG microcontroller)
I checked all my conections and It is all OK and at the entry of the CLT's ADC, I measure 2.65 V (it's depends of the temperature) but when I see the CLT volt gauge, It shows above of 4V and if I disconect the thermistor shows around 6V when it may show around 3.3V.
Fuerthermore, when I increasse the temperature beyong of 200 ºC, the Tunner Studio show a CLT error and the gauge turn to 0 V.
You can see it athe the following clip. https://drive.google.com/file/d/150RFGb4BHba3BtAacuXpdVTHGbhZSdP0/view?usp=sharing
Thanks for all!
Thanks for all!
please upload your tune to rusEFI online and paste the link here
in rusEFI console please type
tempinfo
and paste output here
I wonder if reading that high is confusing thermistor math
tempinfo
I think the only limit imposed by rusEfi is that if the sensor voltage gets too high (or low) we assume that the sensor is disconnected (or shorted). That limit is currently 4.9 volts when using a pullup to 5 volts.
After looking closer at your schematic....is this Frankenso or some other board? I don't see the required voltage divider to divide the 5v input down to the 3.3v usable by the STM32's ADC.
Hi everyone!
This is the tune URL: https://rusefi.com/online/view.php?msq=250
I'm sorry, I didn't congufigurate my drive properly. Now the clip is available here: https://drive.google.com/file/d/150RFGb4BHba3BtAacuXpdVTHGbhZSdP0/view?usp=sharing
My pull-up resistor (or bias resistor R11 ) is at VDDA = 3.3 V. VDDA is the ADCs supply voltage.
Because of this pull up resistor, if i disconect the thermistor, the voltage at the entry opf the adc (or at the output of de voltage driver) must be VDDA = 3.3V.
Why the TunnerStudio shows 6V?
Hi!
[/img]
It Is a custom board based on Frankenso (STM32F407VG microcontroller).
Regards
Hi!
Here is the results of typing "tempinfo":
because rusEFI firmware expects same voltage divider on all analog inputs
if you do not have same dividers on all analog inputs (with exception of VBatt) you would need custom firmware to handle this custom hardware setup.
Can you share the full schematic?
Thanks AndryB!!
I have changed the value of the analog divider ratio to 1.66V and CLT and IAT sensor show the temperature correctly.
But when I see the voltage raw, the voltage of the IAT is OK but the raw of voltage of the CLT is wrong:
[/url]
In my case, for the IAT and the CLT I have the same pull up resistor but the thermistor are diferent:
- IAT sensor is a 2K thermistor at 25ºC.
- CLT sensor is a 10K thermistor at 25ºC.
Here is the current view of my tunner Studio where you can see the volages of the sensors:
AndreyB when you said that we should need the same dividers, it means I need the same thermistors with the same resistance too and if we use different thermistors we need to change something at the sofware of the config.ini file of the TunnerStudio project or the rusEFI firmware. Is it correct?
Actually with this config, I can saw temperatures up to around 250ºC.
Again, thanks you very much!
This divider is what was referenced.
Sharing the full schematic helps us understand what kinds of issues may be happening. We can look at it and know what voltages to expect. etc.Welcome to the friendlier side of internet crazy
Thanks for your answer!
I don't have a divider after the OPAMP. This is all:
In my case VDDA = 3.3 V, so cf I didn't conncet anything, the output voltage of the OPAMPs may be VDDA = 3.3 V or a little bit lower.
This is due to this pull-up resistance, a voltage divider after the OPAMP is not necessary since the maximum output voltage is limited by this resistor at 3.3V.
Wouldn't that be so?
Regards.
My perception is that you have refused to share full schematics, this could affect my motivation to help going forward.
default rusEFI firmware expects same voltage divider on all analog inputs and all calculations are affected by that parameter.
At this point I would suggest we do not debate if that's necessary or not necessary, I would suggest focusing at this fact and the consequences of that fact on your setup.
Since you have ignored the request to share full schematics I am not able to help you effectively.
It would appear you do not understand certain things about opamps. Opamps have many characteristics that are important. However with out knowing this level of information I cannot help you. It's not a question of if I want to help you, I simply don't have enough information to be able to help you.
Hi everyone!AndreyB wrote: ↑Wed Oct 28, 2020 2:37 pmMy perception is that you have refused to share full schematics, this could affect my motivation to help going forward.
First of all, I want to apologize, I didn't pay attention to the line in which you asked me for the full schematics, It's was my fault.
Here are all :
- Analog:
- Power:
- Inputs / Outputs:
- uC:
Again, I beg your pardon.
Regards.
When running rusEFI on on 3 volt stm32 chips all our boards have same voltage divider ratio on all analog inputs - the ratio is 2:1 on Frankesno and 1.66:1 on microRusEFI
We have corresponding setting which in your case you would have to set to "1" - setting screenshot above. This way you would have to account for your custom per-channel voltage divider in your calibrations. While we have not done so I guess it should be possible?
Actually the only configuration that throw a coherent temperature measure is setting the parameter Analog divider = 1.66.AndreyB wrote: ↑Thu Oct 29, 2020 11:55 amWhen running rusEFI on on 3 volt stm32 chips all our boards have same voltage divider ratio on all analog inputs - the ratio is 2:1 on Frankesno and 1.66:1 on microRusEFI
The Clt thermistor is disconected in this picture, if I connect it, the clT temperature gauge show the same temperature than the IAT gauge and its the same than the real temperature.
The only thing that is diferent is the voltage raw gauges. These are refered to 5V and I have the reference with the pull-up resitor at 3.3V.
I hope that my information helps you.
Thanks you so much!
I do not see any questions, I do not see "tempinfo" detailed output.
Do you have any questions? What are your questions?
What opamp are you using? Opamps do not go to the rails, as well there are things like offset, and gain which are important.
What program is this done in? Could you share the native file format? I'm assuming your program can do things like highlighting a net, which is handy when trying to track tagged nets like VDDA.
For @Andrey, he's using the 3V for his bias voltage to things like CLT etc, not 5V, so his output can only go up to 3V. He has the divider on the input instead of the output. His circuit is not 12V tolerant, if he shorted that accidently, the ECU is toast, it will probably blow the STM32. However his inquiry is about the scaling of the signals. His scaling is very non-linear and is very much not like any of our boards. I think he's asking how to scale his voltage so he can get a number in engineering units.
Plenty of opamps can actually drive to the rails - the MCP6004 used on Frankenso, MRE, and Proteus can, for example. The opamp's open loop gain is largely unimportant, as nobody runs an opamp without feedback. Offset is important, but is usually small enough we don't care for stuff like this.
Yes, this is my actual concern here. VDDA shouldn't be anywhere near an output pin. 2.5k without any clamping is practically a short circuit when presented with ESD or noise from the ignition system.
Set the analog input divider to 1.0, and the stm32 vref to 3.3. That should get the thermistors working okay. The MAP and TPS might require "technically wrong" calibration values, but they can be made to work just fine if the actual voltages are divided by the ratio of the dividers on those inputs.
Many years ago, I measured the MC6004 (and several other rail to rail opamps) to have issues around 10mV to 20mV from the bottom rail. For Frankenso I choose this opamp because it was far closer to the rails than several others that we tried, and most of the issues for the MC6004 were at the top end, which we intentionally avoid. I guess the skewing near th rails, or offsets near the rails or simply not getting to rail, when near the rails is considered close enough to be rail to rail, but keep in mind you typically can't hit the rails, the question is how close you can get. As well the circuitry used to get close to the rails can cause instabilities, oscillations, etc, which do not exist when you're in the middle of the opamps range.mck1117 wrote: ↑Fri Oct 30, 2020 10:12 amPlenty of opamps can actually drive to the rails - the MCP6004 used on Frankenso, MRE, and Proteus can, for example. The opamp's open loop gain is largely unimportant, as nobody runs an opamp without feedback. Offset is important, but is usually small enough we don't care for stuff like this.
