The firmware installed on the stm32 is from the na6 files. Then the jumpers make it compatible with the na8. Is this correct?
I’ve sat on this board for a while and I’m trying to dive back in. Hope this is the right place for this question.
Thank you
Frankenso pnp with jumpers for 94-95 Miata
Re: Frankenso pnp with jumpers for 94-95 Miata
You are correct. The firmware is the same, the jumpers are different. The tune will be different too to deal with the different engine size and some different I/O.
https://github.com/rusefi/rusefi/wiki/Miata-NA-48-pin-board-for-MRE is about a different board but might be helpful - second and third pictures show same board set for 91 vs 94. Kind of show areas of change.
