Calculate VSS with RPM vs GEAR position
nmstec
Post by nmstec »
In the rare case you have a car that has no actual VSS, but need an idea of speed, this would be the future LUA script to do so.
SCRIPT GOES HERE
Info go here:
FIRST GEAR
22kph @1890 - 85.90
25kph @2189 - 87.56
31kph @2768 - 89.29
39kph @3497 - 89.66
49kph @4361 - 89.00
51kph @4595 - 90.09
OVERALL AVERAGE RPM/88.583
SECOND GEAR
27kph @1654 - 61.25
29kph @1777 - 61.27
33kph @2013 - 61
35kph @2172 - 62.05
40kph @2491 - 62.27
59kph @3760 - 63.72
68kph @4244 - 62.41
73kph @4597 - 62.97
OVERALL AVERAGE RPM/62.117
THIRD GEAR
31kph @1552 - 50.06
35kph @1763 - 50.37
39kph @1937 - 49.66
46kph @2325 - 50.54
53kph @2695 - 50.84
72kph @3778 - 52.47
85kph @4414 - 51.92
91kph @4672 - 51.34
OVERALL AVERAGE RPM/50.9
FOURTH GEAR
42kph @1787 - 42.54
47kph @1937 - 41.21
49kph @2052 - 41.87
53kph @2191 - 41.33
79kph @3433 - 43.45
91kph @3853 - 42.34
99kph @4233 - 42.75
OVERALL AVERAGE RPM/42.21
FIFTH GEAR
56kph @1969 - 35.16
59kph @2086 - 35.35
63kph @2239 - 35.53
76kph @2731 - 35.93
94kph @3419 - 36.37
101kph @3659 - 36.22
OVERALL AVERAGE RPM/35.76
SIXTH GEAR
70kph @1971 - 28.15
74kph @2118 - 28.62
80kph @2283 - 28.53
86kph @2464 - 28.65
105kph @3062 - 29.16
122kph @3345 - 27.41
OVERALL AVERAGE RPM/28.42
"Dave B. 5:03 PM
Re: Calculate VSS with RPM vs GEAR position
nmstec wrote:
Mon Jun 20, 2022 9:18 pm
In the rare case you have no VSS, want one, and ALSO HAVE GEAR POSITION SENSING!
nmstec
Post by nmstec »
mck1117 wrote:
Mon Jun 20, 2022 9:19 pm
Very true. But hey, Andrey says he wants this info saved, so I figure fuck it. Gear sensing AND A 30K sequential tranny lol
"Dave B. 5:03 PM
Show me your Lua :) Do you already print speed into console? Did you try Lua PWM frequency?
nmstec
Post by nmstec »
Haven't gotten to it yet, working slowly now. Was finishing up with the LSX.
"Dave B. 5:03 PM
nmstec
Post by nmstec »
Basic write up at home, with 0 tests done, and voltage values pulled out of my very fine magical ass.
local gear = 0 --added for later usage and data logging
local vss = 0
local ratio = 0
function onTick()
    rpm = getSensor("RPM")
    gPos = getAuxAnalog(0)
    if gPos < 0.7 then --Reverse
        gear = 0--no fucks given
    elseif gPos > 0.7 and gPos < 1.1 then --neutral
        gear = 9--noone cares
    elseif gPos > 1.1 and gPos < 1.6 then --1
        ratio = 88.583
    elseif gPos > 0.7 and gPos < 1.1 then --2
        ratio = 62.117
    elseif gPos > 1.1 and gPos < 1.7 then --3
        ratio = 50.9
    elseif gPos > 1.7 and gPos < 2.4 then --4
        ratio = 42.21
    elseif gPos > 2.4 and gPos < 3.0 then --5
        ratio = 35.76
    elseif gPos > 3.0 and gPos < 4.0 then --6
        ratio = 28.42
    end
    if ratio > 0 then --hack to make sure never divide by 0. set to R
        vss = rpm/ratio
    else
        vss = 0
    end
    print(vss)
 end
"Dave B. 5:03 PM
