rusefi.com • "Failed to erase flash at 0x080E0000"
Posted: Mon Oct 17, 2022 5:19 pm
by tmbryhn
I have three ECUs on the bench running the latest Proteus fw. I'm using the exact same .msq for testing.
One of them is running a F427ZGT6, and throws the following error "Failed to erase flash at 0x080E0000" when trying to eg. burn a new EGO Sensor Cirrection(value),changing Custom MAP sensor high/low values, or pedal sensor voltage values. Probably other variables too.
I tried to de-solder the "defective" MCU, an solder in a new MCU of the same part number. Same problem.
The other rund F427ZIT6 and F429ZGT6 and works just fine burning the same values.
To summarize:
F427ZIT6 - OK
2x F427ZGT6 - "Failed to erase flash at 0x080E0000"
F429ZGT6 - OK
Am I a victim of a crappy counterfeit batch, or is this a firmware bug?
