[help needed] VVT OUTPUT 1 Problem (MicroRusEFI)
gustavoportilla
Hello, I am experiencing a problem with the VVT output 1 on the microRusEFI board. After a few accelerations, the VVT output 1 remains activated, the pin used is pin 7 (Low Side 1). I have also tested with double VVT output using pin 3 (Low Side 2) and the VVT output 2 works correctly, there are no problems.
gustavoportilla
Re: VVT OUTPUT 1 Problem (MicroRusEFI)
https://github.com/rusefi/rusefi/wiki/rusEFI-Quick-Start-PDF is asking for logs
Not much life on the forum either way
gustavoportilla
Hi, I'm sending records
Last edited by gustavoportilla on Wed Dec 25, 2024 7:45 pm, edited 1 time in total.
gustavoportilla
AndreyB wrote: ↑Sun Dec 22, 2024 3:43 pmhttps://github.com/rusefi/rusefi/wiki/rusEFI-Quick-Start-PDF is asking for logs
Not much life on the forum either way![]()
