java console has a gauge which displays the signal dwell as measured by out build-in logic analyzer. triggerinfo would tell us that primary logic input is http://i.imgur.com/e34b5vN.png and showconfig shows that one of the injection channels is http://i.imgur.com/ILq2dgd.png
Now let's reset everything to the default state - that's set_engine_type 20, and also enable self_stimulation to turn the whole firmware logic on.
Perfect, now we put a jumper wire between PA8 and PB8 and start the console, set RPM to a higher value, restart the console and look at the numbers.
I do not like all this at all, to be continued.
