How to compile the dev console
Posted: Tue Oct 28, 2014 1:38 pm
Click here for info on how to compile the firmware
The dev console is written in Java. The source code comes with a IntelliJ IDEA project and ANT build script.
1) You can download Community free open-source edition of IntelliJ IDEA from https://www.jetbrains.com/idea/download/
2) Install it
3) Download & install Java JDK (Java Developer Kit. The regular JRE - java runtime environment - would not be enough) version 7 or later
4) Start IDEA and point Open Project at your local folder where you've checked out http://sourceforge.net/p/rusefi/code/HEAD/tree/trunk/java_console
5) If you get a yellow 'Project SDK is not defined' warning, click on 'Setup SDK' and point at your JDK installation from step #3
2) Install it
