Target Idle v CTS
Target Idle v CTS
Is there a table for target idle v CTS?
Re: Target Idle v CTS
CTS=CLT=coolant temperature sensor?
Idle in general is a mess, but kind of yes:
and
typedef enum {
* In auto mode we currently have some pid-like-but-not really PID logic which is trying
* to get idle RPM to desired value by dynamically adjusting idle valve position.
* TODO: convert to PID
IM_AUTO = 0,
* Manual idle control is extremely simple: user just specifies desired idle valve position
* which could be adjusted according to current CLT
IM_MANUAL = 1,
Force_4b_idle_mode = ENUM_32_BITS,
} idle_mode_e;
* CLT-based adjustment for simple manual idle controller
* offset 6200
float cltIdleCorrBins[CLT_CURVE_SIZE];
OK, I've found that. What is the syntax to set that up from Suzuki_vitara.cpp?
