Hi all
ScubaSteve
Hi all
Post by ScubaSteve »
First let me say this project is absolutely brilliant!
On the drive back from work/university I was pondering a good senior project (a ways away) and thought a custom ECU might be cool to look into. Can't say I will be much help yet or at all, but I'm really excited to play around with what you got here!
Now I just have to get a small engine to fry..
Re: Hi all
ScubaSteve wrote:Now I just have to get a small engine to fry..
Smallest so far is 72cc, but that's a lot of mechanical modifications to fit an injector etc.
Get yourself a 3 cylinder something for a test mule, that would be fun! :)
ScubaSteve
Re: Hi all
Agree'd!
I seem to be having a slight issue with the simulator. I can only get the "20150503" version to work (and all previous). The next two updates open display "1200 RPM" and then change to "N/C" and the top bar displays "DISCONNECTED" after a second or two
However, only the latest version will even load the table editor.
Im on windows 7, just updated my Java version.
Re: Hi all
Will check simulator tomorrow. BTW I've just adjusted the simulator wiki page to show a simpler way to connect Tuner Studio.
Go get an stm32f4discovery :)
Re: Hi all
Welcome along. I've also been modifying a small engine, but haven't made much progress in recent years as I got a snow blower that now works. Any how, here is a page where I have documented the effort. http://jaredharvey.com/Files/projects/Engine_control/snow_blower/snow_blower.htm
Good to hear from you and I look forward to seeing you around.
ScubaSteve
Re: Hi all
kb1gtt wrote:Welcome along. I've also been modifying a small engine, but haven't made much progress in recent years as I got a snow blower that now works. Any how, here is a page where I have documented the effort. http://jaredharvey.com/Files/projects/Engine_control/snow_blower/snow_blower.htm
Awesome project! I'll likely be following much of your work initally to get a better understanding of everything!
russian wrote:Will check simulator tomorrow. BTW I've just adjusted the simulator wiki page to show a simpler way to connect Tuner Studio.
Awesome, I'll be picking one up soon!
I'm kinda sad now. I had an old Honda VF500 sitting arround but I junked it a few months back. Would have made for a good mule :(
Re: Hi all
Should be better now.
ScubaSteve
Re: Hi all
Confirmed AOK!
Also..
Could I presumably drive a AEB 1.8L from a passat with the STM32?
Re: Hi all
Probably. Was that mechanical fuel injection? What are the pieces. Do you have Hall pickup, electronic fuel injectors, coil and distributor ignition?
Re: Hi all
ScubaSteve wrote:Could I presumably drive a AEB 1.8L from a passat with the STM32?
well, technically you would need an I-O board between passat and stm32
ScubaSteve
Re: Hi all
kb1gtt wrote:Probably. Was that mechanical fuel injection? What are the pieces. Do you have Hall pickup, electronic fuel injectors, coil and distributor ignition?
Everything except Mechanical Fuel Injection (I think..). I started a data thread to gather all the info!
http://rusefi.com/forum/viewtopic.php?f=3&t=895&p=16061#p16061
Such as the Frankenso or Frankenstein? (Or all those AIO)
