Hello all out there
Im from sweden and have a question
About trigger weel pattern
See i dealing with Mercedes engines And custom make
turbo and stand alone management system
But this rus efi i have to ask
Can this system read for example basic trigger
Its a Mercedes m103 inline 6
And uses a 3segment teeth on The flyweel
Same for v8s between 86-91
4 segments 8cylinders
This m103
Single coil
Rear mounted Crank sensor inductive( Vr)
Distributor driven by The camchaft
I did several setup with autronics and with perfect result
So can franken system handle this it opens a new World over here for me
Thanks in advance
Robert from sweden
Hello sweden here and a trigger weel question
fullboost
Re: Hello sweden here and a trigger weel question
Hello and welcome!
We can add a new trigger shape definition once you have some rusEfi-compatible hardware! See also http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Unknown_trigger_type see also http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger
fullboost
Thanks for your wellcome
So this Means i can install
The system just to get Crank trigger pattern into The software
After i Crank The engine does it find The pattern by The software
And What is next step to go
Thanks for fast reply
you install, remove spark plugs, crank for some time.
you email me the log files created by our console software.
I look at the log files, update the firmware source code, you take fresh firmware and start your engine.
http://rusefi.com/forum/viewtopic.php?f=3&t=917 is a fresh example of how this goes
fullboost
Well Im impressed and
I understand more now
Cos this is Something to aim for
In The future
Im really exhited to try out One of this ecu
And it looks like It is Very powerful too
OH does it runs sequential or How does it handles The fueling
In The future
Still need better navigation between wiki pages, but there is some content on the wiki already: http://rusefi.com/wiki/index.php?title=Manual:Software:Fuel_Control
fullboost
Yes that seems good i checked it out on The link
I think next step is to try One of those ecu
Into My engine
Is it external map sensor or buildt in sensor
Into My engine
No build-in sensor on http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_boardfullboost wrote:Is it external map sensor or buildt in sensor
fullboost
Allright thats no problem
And i can use a external typ GM map sensor
N/a or forced induktion
Yes, yes and yes.
fullboost
Nice and Many thanks for your help and Quick answers
