Ha! Didn't fix it
. You may wonder why I'm so happy, well, I did manage to fix it
It's been a while since I had a bug that really challenged me :p. It turned out that the second processor on the mini usb side can pull the STM32F407 into reset, which it does, right until after enumeration. The solution was to remove a soldered jumper and a resistor. SB11 and R68 to be precise. I must admit that I sadly found something like this one the STM forum, so I can't claim I invented it
On a more serious note, the audio circuit has influence on the injector pulse width right? To work around this, did you guys just remove those chips or is it the R/C/L networks that are causing the problem?
FOR MIATA PEOPLE WANTING SPEED DENSITY WITH MAP:
In the AFM there is a contact for the fuel pump which shuts of the fuel supply if it does not measure air. So when you throw the AFM out of the window, your car will not start! Trust me! The easy solution is to jumper the two contacts at the end of the AFM plug wire, I think you can also jumper a contact in the OBD I box near the AFM (not sure). The nice way would be to rewire it (which nobody will do). Almost ready for boost!
Wideband will be installed next week, when the basemap is done I'll post it and the config on the forum (still editing stuff, especially cranking and temp correction).
