[rusEfi] Моё Чудо ... VW Passat B4 ABA ... #16
Log
- 2015-09-05_11.31.02.msl
- (356.12 KiB) Downloaded 703 times
Thanks @russian he fixed probles ...
i run today maybe 20 minets and it`s almost perfect ...
spin engine to 6800 rpm its maximum to may camshaft ... CAMSHAFT (268°/260°-STREET) ...
on brord blinking just one LED (Ignition coil) ...
this data log but i thing its not shows correct ...
- 2016-06-13_17.54.08.msl
- (3.5 MiB) Downloaded 860 times
I dont have enough time to finishing this top cover ...
plus not enough experiences in 3D design ...
it is open project ...
https://www.tinkercad.com/things/a1djBGX29Xs-rusefi-top-case-box-cover/edit
- rusefi_top_case_box_cover.zip
- (121.44 KiB) Downloaded 404 times
I make my video to ...
Rims size 17
Tiers front 215 / 45 / 17
Tiers rear 245 /45 / 17
Lbs GVWR 3902 GAWR lbs front 2050 / rear 2072
vw passat b4 2.0L 8v gear ratios
CNL 3.778 2.118 1.429 1.029 0.837 3.684
Speed sensor work properly ...
I fix the car (supercharger) ...
recorded logs ...
Maybe someone will be interesting ...
Any help is appreciated ...
recorded logs ...
- 2016-11-15_16.43.54.msl
- (1.69 MiB) Downloaded 657 times
- 2016-11-15_16.29.54.msl
- (3.22 MiB) Downloaded 670 times
today log
- 2016-11-20_16.02.47.msl
- (4.07 MiB) Downloaded 651 times
I'll see what I can do here:
- What firmware version are you running? I need that to use the proper ini file for TS
- You are generating a lot of errors. Looks like one exactly every ten seconds. No idea what's up with that.
- Your intake temperatures get insanely high. Over 200C.
- You are running off the MAF, but you have a MAP sensor. I suggest using speed-density algorithm
- Looks like your fuel-tune needs improvement/ is possibly non-existing
- Your ignition table looks super-conservative in the lower load cells
rusEfi bundle snapshot_20161103_1854_rusefi
generating a lot of errors... i dont have no idea ...
intake temperatures ......... the next step of the installation intercoolers air\air water\air ...
in TS does not show 200C ??? and therefore may be error ???
I understand if MAP ON then MAF will turn off automaticaly ???
yes I use MAP speed-density ...
what should I need change fuel-tune improvement ???
what should I need change in ignition table ???
Thank you ...
Thank you ...
10 seconds is the default warning error period (this is to reduce the noise in the console messages but also affect logs, I guess I should improve the code so that console period does not affect logging frequency) https://sourceforge.net/p/rusefi/tickets/323/stefanst wrote:Looks like one exactly every ten seconds. No idea what's up with that.
CUSTOM_SYNC_ERROR_2 = 6037,
CUSTOM_LOGGING_BUFFER_OVERFLOW = 6044, - comm issue not important
CUSTOM_OBD_SKIPPED_SPARK = 6045 - that's ticket #299
CUSTOM_TOO_LONG_FUEL_INJECTION = 6050 - that's really interesting, that's injectors duty cycle?!
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/controllers/algo/obd_error_codes.h
as long as fuel algorithm is Speed Density MAF sensor could be just logged but not used for fuel logic
VBatt (white line) drops from expected 14v to 2.5 volts from time to time which causes duty cycle to jump to 400%
I wonder if a wire is loose or a poor solder or else?
- screenshot.png (51.57 KiB) Viewed 27480 times
OK first I checked volts problem ...
2.5v it's mean ECU turn off ???
2.5V probably means that it's powered from the USB port I assume is still plugged in.
Yes I use 2 USB from discovery board ...stefanst wrote:2.5V probably means that it's powered from the USB port I assume is still plugged in.
Then you have a problem with your +12V supply or possibly your GND connection.
Power Supply ...
diode leg badly soldered ...
From left First leg badly soldered ...
The GND plane can suck up lots of heat, you may need to keep your iron on it for a long time to get the GND plane to heat up. If you have a 40W or 100W soldering iron you might want to try that. More heat can heat up a local area faster than the typical 20W irons.
It's all about turbo ...
Hello again ...
How to make on RusEFI same signal I needed ... As in my stock ecu ... to make a tachometer work ...
Recorded two tachometer signals ...
The first is the original ECU original tachometer ...
[video]https://youtu.be/mQ5vM8VILws[/video]
The second video is RusEfi ...
[video]https://youtu.be/2ZGCKQhjrqA[/video]
- pic.bmp (3.42 MiB) Viewed 26034 times
rusEfi has two options for tachometer output:
1) dizzySparkOutputPin - This implementation makes a pulse every time one of the coils is charged. uses coil dwell for pulse width
2) tachOutputPin - This implementation produces one pulse per engine cycle. At the moment this implementation uses "pulse duration" setting for pulse width and this width is contant number of milliseconds, regardless of RPM
Looks like what you need is a way to make a 50% duty cycle signal which rusEfi currently does not support. Good news is that should be a simple chagne and I should be able to make this happen https://github.com/rusefi/rusefi/issues/476
