[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) transfer LCD board inside car joystick and button - rusefi.com
What about transfer LCD board inside car joystick and button LED on discovery ???
If it is possible ???
NRF24L01+ 2.4GHz Antenna Wireless Transceiver Module
This module could be made to work, it basically relocates a serial stream. However we already have the ITEAD_HC-0X on the board, which can also remote a serial stream. I believe using the HC-0X would be an easier development cycle. I don't know about how hard the software would be. As well you could use the CAN controller, it can provide 5V, GND and CAN allowing a 4 conductor cable to remote signals. A wireless device runs a risk of failed communications, which might be of concern if you are using it as a kind of dash board.
