[rusEfi] Hunchback 1991 Miata NA/NB2 rusEfi official racecar #20
Re: 1991 Miata #20 Hunchback
Running the harness externally would be a pretty cool look. Kind of like a Borg theme. "We are the rusefi. You will be assimilated. Resistance is futile."
Great wrenching session today! Helps to have all the random parts on the shelve - NA6 to NB2 conversion ask for a 99 fuel rail - we have it, conversion asks for a 94 alternator - we have it!
Axles, ppf, last two control arms, struts are now on the car. There is a hope to start the engine next weekend!
Awesome!
So do I understand that right and the engine and harness are in? Pictures?
Nope, need a couple of vacuum plugs and coolant reroute installed and transmission mounted. Kind of very close to go into the car.stefanst wrote:Awesome!
So you're converting to a return-style fuel system?
I like the idea, since dead-headed fuel systems are an atrocity. But I don't think your stock ECU will still work well after the conversion. It relies on constant fuel pressure at the rail for calculations, Now you have changing pressure.
Started VVT in NA car! Currenly on stock ECU, hopefully tomorrow will make progress with harness and run on rusEfi.
- 20170325_miata_todo.jpg (185.67 KiB) Viewed 40773 times
Harness is now inside the cabin, car goes to a shop for exhaust and alighment. Next weekend is road testing, if things go nicely it goes to a dyno in two weeks.
I'm not sure that we had an answer to this yet...stefanst wrote:So you're converting to a return-style fuel system?
Yes return-style fuel system now. It helped that we had 91, 94 parts and 99 parts readily available
I was trying to add a fuel pressure gauge but got the wrong diameter adapter. Will report how would stock ECU perform AFR-wise, thank you for the hint to look out for that.
Green race car uses pieces of 2002 engine harness - complete under-the-hood piece and a part of main harness.
There are minor differences between 2002 and 2003 wiring (red test mule car is 2003), I am planning a universal Frankenso harness so that same Frankenso could be used on both 2002 and 2003. Technically there is probably an option to modify the 2002 harness to match 2003 but I'd rather not do that.
2002 ECU and main relay:
Main relay is controlled by ignition switch (this is different from 2003 where ECU controls main relay via 3H).
Nothing on 4S (4S is ignition power source on 2003).
ECU is powered from main relay via 4AF (this is different from 2003 where ECU is powered via 4S)
2003 ECU and main relay:
In start or run ECU is powered from Engine Fuse 15A via 4S. (This is different from 2002 - nothing on 4S in 2002)
ECU controls main relay via 3H. (This is different from 2002 - nothing on 3H in 2002)
ECU gets +12v from main relay output 4AF which is used as +12v source for VVT (4D) and IAC (2P).
For my universal 2002/2003 harness I plan a little toggle switch between 4S and 4AF:
Toggle switch ON would feed Franenso on 4S wire on 2002.
Toggle switch OFF would disconnect ignition lock +12v from main relay +12v in order to properly operate on 2003.
See also http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2002
See also http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2003
Three cabin fuses are needed to run 2002 engine - cabin fuse box is replaced by a couple in-line fuse holders. Main relay box is used as is. 2002 harness ground goes to top of intake close to throttle body, 2002 harness power is taken from main kill switch. There is a small toggle switch replacing ignition key - 1991 ignition key is not used at all.
Starter and alternator are still on 1991 harness, alternator is not controlled by rusEfi.
I will borrow Stefan's idea of soldering fly-back IAC and VVT diodes right to the connector adapter board - the pins to connect are conveniently located close to each other.
Electrical checklist:
- Brake lights
- running lights
- Hazards
- Blinkers
- low-beam head lights
- radiator fan
- wipers
- gauge backlight
- fuel gauge
- fuel pump (requires main relay)
- engine starts & runs
- alternator charges
- dummy light
- tachometer
- oil pressure gauge
- CLT gauge
- fuel gauge
- WBO power
- camera power supply
- cool shirt power
Is the car going on a dyno any time soon?
I'm curious for obvious reasons....
Little unplanned holes are in the way. Also we've probably made the mistake of removing these low-end butterflies from the intake. Long story short I am currently in PANIC MODE - race is in 18 days, car is not ready. More details later tonight
- water_cap_problem.jpg (147.09 KiB) Viewed 40658 times
You can borrow my VTCS intake.
I also have a spare VICS intake sitting in a box. Can deliver.
[video]https://www.youtube.com/watch?v=D8MAZQrYczs[/video]
Things are starting to look better!
Tach works, temp gauge works! Laptop mount is mostly ready for road tuning, still need to wire warning light and figure out why VVT does not work.
[video]https://www.youtube.com/watch?v=owg1SdErA7I[/video]
You could run stock ECU in parallel, stock taking care of the VVT and rusefi running fuel and spark. A bit complex, but.....
C'mon, you cannot be serious! That's... Not the right way! We know two rusEfi boards have controlled VVT on two different cars, should not be much different on the 3rd car.stefanst wrote:A bit complex, but.....
And yet you fail so far....russian wrote:C'mon, you cannot be serious! That's... Not the right way! We know two rusEfi boards have controlled VVT on two different cars, should not be much different on the 3rd car.
More news tonight?
I don't know why he's having problems, he's got a Gen2 engine harness spliced with a Gen3 engine harness, which is then spliced with a Gen1 body harness. I know how to fix it, get a ford harness and add that I think you can do your own version of monkeys writing Shakespeare, but with harnesses and engines.stefanst wrote:And yet you fail
Good luck. I'm sure you have a minor electrical problem. Probably just a wire crossed or something like that. I'm sure you'll find the issue in that spaghetti and then you'll be good. Happy hunting.
It was diode soldered not where it should be soldered, I got myself confused with the pinout. Notes at the bottom of http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_2003 are corrected now and VVT works. And rusEfi now knows AFR, and warning light works just needs to be soldered. Little steps every day
- 20170427_220611.jpg (621.78 KiB) Viewed 40596 times
Oh, and you can see WHP predictions at the bottom. Why wants to make their prediction?
Some one has been after me about SI vs ANSI units, so....
100 kW.
100 kW.
Is it an educated guess? or just a shot in the dark?
Stock is rated at 140hp at the crank. Deduct 10% for drivetrain loss gets you 126. That's 94kW. Deduct 2kW for 'random' spark tune and you get 92kW. Which presumably makes it an educated guess, but it could still be waaaaaaay off. I'm hoping for more
But stock means injection times designed mainly for ecology and pollution control. This one aims for more power (otherwise, why would you want to remove stock ecu?)
So, I'd say 102kW, and it's more of a random shot - since I still don't know how much more power you can get off stock engine with a custom ECU...
Don't forget detonation pressures make higher hp. It does not have knock so detonation pressures would be done to detect.
30 highway miles with TS auto-tune. Car is hellasweet! https://svn.code.sf.net/p/rusefi/code/misc/logs/1991_miata_hunchback/20170429_vvt_first_highway.7z
Monday is dyno day.
Monday is dyno day.
