CJ910/CJ911
nighthunter
donator
donator
CJ910/CJ911
Post by nighthunter »
Hi everybody.
I am continuing my project and my goal is to use as much as possible ICs from ecus i have here. I want to use the supply IC CJ910/911 used in bosch MEG1.0 /1.1s. I will then hopefully redesign the rusefi back to the original MEG casing. I already doing some reverse engineering on this ecus. It uses CC195 for knock and CJ920 for power outputs. And BUZ100SL H brigdes for transmission motors.
My question is if there are any information on pinout/operation of CJ910/911? I cant find nothing on this parts. On the photo of PCB there are 30057 IGBTs desoldered, also the CJ91x and connectors.
andreika
donator
donator
Re: CJ910/CJ911
Post by andreika »
nighthunter wrote:if there are any information on pinout/operation of CJ910/911? I cant find nothing on this parts.
You need to search for "Bosch 30343":
30343 = CJ911
System basis IC with following functions:
- 1 x ISO interface
- System: 5 V, Standby: 5 V, 5 V (operation), Sensors: 2x5 V
- Ignition, RPM-sensor (typ. glitch filter delay time: 12.5 µs), Sustaining control reset
- Switched battery: 1 x HSPS, Main relay control: 1 x LSPS, Signal drivers: 4 x LSPS, Ignition reset
- Overvoltage shutdown
In my ECU (ME7.5 8E0 909 557D):
1	GND
2	GND
3
4
5
6	GND
7	Throttle Poition Sensor:G79-2 ECU:73	ECU:73
8	+5V uC
9
10
11
12
13	Throttle Poition Sensor:G185-1 ECU:72	ECU:72
14
15	GND
16	Motronics Engine Control Module (ECM) Power Supply Relay	ECU:21
17	+12.6V switched	test point
18	GND
19	GND
20	Fuse Box 30 bus (via diode)	ECU:62
21	ignition? (connected with 1k5 to ECU:3)	ECU:3
22	Fuse Box 30 bus	ECU:62
23	+5V uC
24	+5V uC
25
26
27
28	+5V standby
29	to Tx of micro	C167:TxD0
30	K-line via 2k5 and diode	ECU:43
31	to Rx of micro	C167:RxD0
32
33
34
35
36	GND
To get an idea what's inside that chip, take a look at the folowing datasheets:
1) Infineon TLE6361G
2) Bosch CY320
They are similar to CJ91x (but not the same).
Dron_Gus
Github Username: dron0gus
Re: CJ910/CJ911
Post by Dron_Gus »
andreika wrote: 1) Infineon TLE6361G
2) Bosch CY320
Sorry for offtopic.
TLE6361 looks interesting. Don't you know where to get several (no fake). Digikey and Mouser don't have on stock.
Re: CJ910/CJ911
Dron_Gus wrote:Digikey and Mouser don't have on stock.
https://octopart.com/search?q=TLE6361
There is a minimum quantity of 28 for this order.
Dron_Gus
Re: CJ910/CJ911
Post by Dron_Gus »
Same situation for Russian suppliers. Minimum quantity is 19. eBay sellers give no faith.
A bit of googling gives me another interesting IC - TLE7368. While TLE6361 is overkill, TLE7368 looks good choise to replace TLE4267 and batch of LDOs currenty used in my design.
