Unit tests
Unit tests
Hi,
what about using a framework for unit tests? They offer out-of-the-box functionality for several repetitive tasks (e.g. assertions), annotations (useful for integration with other tools, such as code coverage or continuous integration servers). Moreover - they display tests results in user-friendly ways. In fact, they render reports, not only for errors but also for successes.
For example, I can recommend CppUTest. I've been using it for several months in commercial projects. It's easy to use. When you execute your tests, they can be displayed on Eclipse like this:
https://raw.githubusercontent.com/arstrube/images/master/cdt.testrunner.cpputest/eclipse-cpputest-3-ran-3.png
And CppUTest can just be added on top of the existing tests, I think. By annotating them. At least I think so.
Re: Unit tests
What problem are you trying to solve?
We have https://github.com/rusefi/rusefi/tree/master/unit_tests without any external framework, and jenkins to run it, with results published in github https://github.com/rusefi/rusefi/commits/master
Re: Unit tests
The ones implied on the advantages of test frameworks I mentioned - the manipulation of tests in a computable way, for example for seamless integration (not manual integration) with Jenkins.russian wrote:What problem are you trying to solve?
Can you please paste here an example of a test report? Thanks in advance!
Re: Unit tests
With very little human resources available I am not convinced that switching from current bare-bones unit test framework to a better one is justified - at the moment I am not aware of any specific advantages worth the trouble.
There is no report at the moment - at the moment there is only process exit code, it's either 0 for sucess or not zero for failure.
current gap 11.666600/0.090909/33.000000 c=174999 prev=15000
TT_NISSAN_SR20VE_360 isSynchronizationPoint=1 index=183 SHAFT_PRIMARY_RISING
nextTriggerEvent index=184
index=0 3
All triggers exported to triggers.txt
C:\Program Files (x86)\Jenkins\workspace\rusEfi unit tests from GITHUB\unit_tests\build>IF NOT ERRORLEVEL echo UNIT TEST FAILED
echo was unexpected at this time.
C:\Program Files (x86)\Jenkins\workspace\rusEfi unit tests from GITHUB\unit_tests\build>IF NOT ERRORLEVEL 0 EXIT /B 1
C:\Program Files (x86)\Jenkins\workspace\rusEfi unit tests from GITHUB\unit_tests\build>cd ..
Re: Unit tests
Things have changes since 2017, we now use https://github.com/google/googletest framework
By the way test_idle_controller.cpp would be a typical simple unit test.
- md_sanci
- Github Username: shadowm60
- Slack: Alex M
- Contact:
Re: Unit tests
Hello all,
For building the SW there is somehow a description but what i managed to do is use eclipse for code and build it with eclipse, here have to take care of passing the arguments correctly, i learned that .bat files are ok and describing how to do it.
For unit tests, i copied them (actually everything) on workspace folder and tried to do unti tests.
there is a jenkins file, but i cannot seem to execute it correctly, i have installed the compiler it needs, but still having some issues.
Is there a way to make execute them? i would like to execute them all, then add my code and see if the report is ok and add some extra stuff? Or should i just spend more time reading about the google test framework?
Re: Unit tests
cd unit_tests
make
build/rusefi_test.exe
and that would run unit tests!
You do not need anything related to Jenkins to run tests locally and manually.
as for adding new tests, just add new method like "TEST(util, crc) {"
make
Re: Unit tests
Hi,
I've spent some time to figure out how to compile the rusEFI-Code with the right version of Make and the GNU Arm Embedded Toolchain, this works fine now (despite the 17 warnings), but I am not able to compile the unit_tests. I didn't make any changes to it, I've got the repository-files from April 12th 2022. Besides the displayed version of Java SDK I've also tried versions JDK 1.7 and JDK 1.8, which lead to an "unexpected '('" error. I am using Windows 10. Can you tell me what I'm doing wrong? Are there more details I can provide? Thank you in advance!
- make-version, java-version and compiling error
- forum_make_unit_tests_error.jpg (411.38 KiB) Viewed 4711 times
Re: Unit tests
I think there's no guarantee that it will compile at all on Windows at this point. It's much easier to get it set up if you use WSL: https://docs.microsoft.com/en-us/windows/wsl/aboutrubwen wrote: ↑Tue May 24, 2022 4:30 pmHi,
Re: Unit tests
"Files" seems to be part of "Program Files" with a space which seems to not work well
progra~1 would often work instead of "program files" as a folder name without a space.
Matt, it would _totally_ compile on Windows for sure.
Re: Unit tests
I've made it smarter https://github.com/rusefi/rusefi/commit/6df7d90765db63f401b69a1925be8e25b31f26dd
Re: Unit tests
This was it, thank you very much, I should have seen that myself. Is there some kind of documentation about the unit tests? I didn't find any information about it besides this thread. I compiled the unit_tests, ran the rusefi_test.exe and got the trigger images from the triggers.txt, but I am not sure what to do with these results. The last part of rusefi_test.exe tells me which tests have failed, but without a hint of what went wrong.
FYI, the rusefi_console.jar path in the last line of firmware\gen_trigger_images.bat didn't work for me because there isn't a java_console_binary subfolder, the rusefi_console.jar was located somewhere else:
java -cp ../java_console_binary/rusefi_console.jar com.rusefi.TriggerImage
- Result of rusefi_test.exe
- forum_rusefi_test_errors.jpg (64.28 KiB) Viewed 4566 times
Re: Unit tests
I read this as "I choose to ignore all the information on top and now I have no hints at what is wrong".
Please do not ignore all the infomation on top?
I see that you run unit tests without an IDE and that's strange.
Re: Unit tests
not strange, there are dozens of us!
we use https://en.wikipedia.org/wiki/Google_Test, maybe start thererubwen wrote: ↑Wed Jun 01, 2022 2:49 pmIs there some kind of documentation about the unit tests? I didn't find any information about it besides this thread. I compiled the unit_tests, ran the rusefi_test.exe and got the trigger images from the triggers.txt, but I am not sure what to do with these results. The last part of rusefi_test.exe tells me which tests have failed, but without a hint of what went wrong.
